Knowing Paragon, I would say their stud is correct. The question is whether it is correct for your car. Do you have the AIM? If a stud replaced a bolt in an application which differed from regular production, it will be noted in the AIM, will have a part number, and an AIM diagram will
probably show where it went.
As an example, AC small block cars have a stud replacing one of the RH exhaust manifold bolts in order to mount the compressor bracket. Non AC cars (regular production) do not have the stud. The stud is shown in the AC options section of the AIM.
