Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2007, 01:39 PM   #1
international blue
CF Senior Member
international blue's Avatar
Default 1968 Core Supports
Looking to find or be told information regarding the core supports for 1968 cars, specificly early cars. What were the 327 and 427 core supports and what did they look like. Was the L-88 core support different than the 427 core on the early cars. Also did the core support change to the 69 type at some point during the model year? Does anyone have any definitive data on the 68's in this area?
international blue is offline   Reply With Quote
Old 03-18-2007, 08:50 AM   #2
R1234
CF Senior Member
R1234's Avatar
I have two 1968 core supports. One is for a small block with a/c, which I have been told, is the same as a big block core support.
The other core support is for a small block with aluminum radiator.
Bryan
R1234 is offline   Reply With Quote
Old 03-19-2007, 10:17 AM   #3
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Quote:
Originally Posted by 68rdstr View Post
I have two 1968 core supports. One is for a small block with a/c, which I have been told, is the same as a big block core support....
Correct as I understand it. The AC smallblocks and the AT smallblocks got the big 4 row Harrison radiators, supports, and shrouds used on the L-36 big block cars. No surge tanks with these radiators.
Quote:
...The other core support is for a small block with aluminum radiator...
Also correct as I understand it. This application is supposed to be a different support. Fan shroud should be the round steel version.
I'd be willing to bet JohnZ or Joe Lucia with the NCRS would know for sure.
Easy Mike is offline   Reply With Quote
Old 03-19-2007, 06:15 PM   #4
JohnZ
CF Senior Member
Support Corvetteforum!
That's correct. '68 small-blocks with 4-speeds and without A/C used the same aluminum radiator and expansion tank as the midyears, with the "pin" mounts at the bottom. Small-blocks with A/C or automatic transmission used the copper/brass radiator with the "saddle" lower mounts and no expansion tank. Two different radiator supports, as the lower "saddle" mounts were welded to the support, the lower "pin" mounts used a different lower channel, and the upper mountings were also different.
JohnZ is offline   Reply With Quote
Old 03-19-2007, 08:19 PM   #5
international blue
CF Senior Member
Can anyone post a pic comparing the two? What does that lower channel look like and how do the pin mounts look. I am guessing I have a pair of 68 SB supports, but am not sure.
Old 04-01-2007, 11:27 AM   #6
R1234
CF Senior Member
R1234's Avatar
Quote:
If I get a chance to go by my parts storage location I can get a pic of the bb or sb with a/c support. Post a pic of your sb with alum. rad. supports. I'm sure somebody here can tell you what you got.
Bryan
Reload this Page 1968 Core Supports
Tags
1968, core, corvette, support
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Installed New One Piece Fuel & Return Lines on 1968 Coupe... Paul Borowski C3 Tech/Performance 10 04-02-2005 06:57 AM
The brown truck is on its way with my DeWitt Rad buffed1978 C3 Tech/Performance 21 01-08-2005 07:50 AM
group purchases?? core supports..seat covers.. Detroit Vette C3 Tech/Performance 32 12-11-2003 11:06 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
