Greg, you want the GM #3911068 springs, still available from GM - 80# closed, 200# open at 1.25" installed height (Federal-Mogul #VS677 is the same spring).
O.D. - 1.239"
Free length - 2.027"
Wire diameter - 0.177"
Same spring was used on ALL small-blocks, regardless of the cam, from 307 grocery-getters to Z/28's with the "30-30" cam; that's the beauty of the Chevrolet factory performance cam designs - the flank profiles don't need heavy springs to manage the dynamics, and the soft action makes the system bulletproof.
