Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-13-2006, 01:16 AM   #1
roti83
Junior Member
Default Help ID NOS TI Distributor & Amplifier
Can anyone help me identify the correct year for NOS TI distributor with tag 1111267 DELCO REMY 9K5 with two leads moulded together (one white, one white with green stripe frt & back) which connect to clear rectangular male plug. Distributor housing has casting number 181, back of casting housing for the tach drive gear has a relief hole. Also two small holes on underside of casting between vacuum advance mount bracket and tach drive. Since 9k5 is October 5, 1969 I suspect the distributor was for a 1970 year or was originally purchased in 1970. The amplifier is in the original GM box part number 1115343. Other than the Delco Remy name in raised cast letters on the top of the amp at either end and Delco Remy red and silver tag "PRIMARY AMPLIFIER for magnetic pulse TRANSISTOR IGNITION" on the front face of the amp there are no other markings. The leads are three separate wires - black, pink, olive green(almost a grey) taped together terminating in a rubber moulded round plug. Any help in identifying the correct year(s) and corvette model(s) would be appreciated. Thanks.
roti83 is offline   Reply With Quote
Old 07-13-2006, 05:29 AM   #2
early shark
CF Senior Member
The amplifier is the style used with Transistorized Ignition for 1969, 1970 & 1971 years.
I am not able to help with the distributor.
early shark is offline   Reply With Quote
Old 07-13-2006, 10:27 AM   #3
redvetracr
CF Senior Member
redvetracr's Avatar
Your #267 is an "over the counter" distributor (never installed in a Corvette or anything else as it rolled down the assembly line), the date 9K5 is most likely 1979. Except for the vacuum advance it is the same as almost every other TI.
...redvetracr
PS: I would be interested in purchasing it (and the amp) if they are for sale!! E-MAIL ME IF THEY ARE FOR SALE!! redvetracr@msn.com
__________________
redvetracr is offline   Reply With Quote
Old 07-14-2006, 03:59 PM   #4
roti83
Junior Member
Thanks for your help early shark.
Old 07-14-2006, 04:02 PM   #5
roti83
Junior Member
Thanks for your help redcetracr. I will email you. Does anyone know the significance of the 181 casting number on the distributor housing? Thanks.
Reload this Page Help ID NOS TI Distributor & Amplifier
Tags
1111267, 1115343, 1967, 1969, advance, amp, amplifier, chevy, codes, corvette, delco, distributor, id, part, pulse, ti, vacuum
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
