Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-09-2006, 05:29 PM   #1
alaskacorvette
CF Senior Member
Support Corvetteforum!
Default CE replacement engines
Several questions for the experts... During the early '70s, were CE stamped engines available for all replacement needs? I've seen several LS-6 CE engines but no LS-5 or LT-1s. Is there any decoding information for the CE stamped blocks? Thanks, Jim.
alaskacorvette is offline   Reply With Quote
Old 07-10-2006, 02:49 PM   #2
JohnZ
CF Senior Member
"CE" engines (only available as short-blocks) were made up to replace all production configurations; the only thing a "CE" pad stamp will tell you is which engine plant made it and when it was assembled - there's no configuration information in a "CE" pad stamp.
JohnZ is offline   Reply With Quote
Old 07-11-2006, 12:52 AM   #3
alaskacorvette
CF Senior Member
Default Thanks
John, Appreciate the help! Thanks, Jim.
Reload this Page CE replacement engines
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Big Block Vs Small Block Jclgodale3 C3 Tech/Performance 64 07-20-2005 05:06 PM
Plugs & wires. LT-4 CE C4 Tech/Performance 9 07-21-2003 11:23 PM
69 L-68 3x2 install on CE engine Swamper C3 Tech/Performance 20 06-05-2003 04:25 PM
CE replacement block question midyearguy C1 & C2 Corvettes 13 05-17-2003 02:45 PM
CE engines Fender C1 & C2 Corvettes 18 03-06-2003 04:39 PM
CE Blocks ? What CE Blocks ????? 66BBCoupe C1 & C2 Corvettes 34 03-30-2002 02:20 PM
CE Engine Identification help needed 69L88clone C3 Tech/Performance 13 12-09-2001 08:25 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
