[quote=chewy]....It doesn't have the origonal engine...[\QUOTE
Okay, so you know it's not an original 265.
Quote:
...and I would like to know if the engine the valve covers were on got put in or just the valve covers...I have nothing that gives vin codes before 58. thanks
Corvette VINs were not stamped on blocks until sometime in 1962. If this is actually a Corvette engine, you will need the casting numbers off the blocks, heads, manifold, etc.
You can't go by the valve covers. They're (obviously) old Corvette, but they would fit any small block of the era.
Point to check: are the hold down holes on the valve covers staggered or straight across from each other. That will give us an estimate on age. Older covers have the staggered holes; later covers have the straight. Count fins. 9 fin are older; 7 fin are later.
