Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-19-2006, 01:43 PM   #1
yellow71
CF Senior Member
Default Whats the trick?
I am redoing the rear end on my 71 vert. Have bead blasted half shafts, drive shaft and diff casing so they look new. Here is the problem - it has been a couple of weeks now and they are starting to rust again. My NCRS manual says those parts have a "natural" finish and are "unpainted" and also that points are deducted for rust. My question then is how to maintain the "new" no rust look without painting? I have tried Eastwoods clear Rust Encapsulator and am still getting rust. How about clear polyurethane or clear enamel? I have no plans to have the car judged but want it to look right.
Thanks for any replies
Neil
yellow71 is offline   Reply With Quote
Old 04-19-2006, 01:50 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
Several options:
Coat with PreLube6 (Quanta has it)
Coat with CorrosionX (www.corrosionx.com)
Paint with Eastwood Diamond Clear (satin)
The first two are less likely to result in a deduction, as they aren't "paint", but need to be re-applied every few months.
JohnZ is offline   Reply With Quote
Old 04-19-2006, 02:08 PM   #3
mayberg
CF Senior Member
mayberg's Avatar
I really dig the "cast-blast" paint that provides a fresh cast-iron finish. It goes on easy, and you should be able to get it at your friendly neighborhood parts store. My preference was the NAPA variety, but they switched suppliers. The dupli-color stuff at O'Reilly's is what I use today.
Since you've bead-blasted, you might want to apply some etching primer first before the cast-blast.
mayberg is offline   Reply With Quote
Old 04-20-2006, 02:19 PM   #4
Greg Gore
CF Senior Member
Greg Gore's Avatar
I wonder if cosmolene would be acceptable? This would be a good way to preserve bare steel parts without applying a finish.
Greg Gore is offline   Reply With Quote
Old 04-20-2006, 02:31 PM   #5
GaryS
CF Senior Member
GaryS's Avatar
The only problem with any paint is that it looks painted. If you are looking for judging you will get some hits on that. Cosmolene is VERY greasy - I would stay away from it unless you just want to store something. I use PreLube 6 and swear by it. Buy two cans.
Gary
GaryS is offline   Reply With Quote
Old 04-20-2006, 02:45 PM   #6
Greg Gore
CF Senior Member
Greg Gore's Avatar
Cosmolene is available in different grades. Some cosmolene can be applied in a thin film and will dry to the touch. I would think this would work and is easily reversible.
Old 04-20-2006, 06:23 PM   #7
Chuck Gongloff
CF Senior Member
Chuck Gongloff's Avatar
Neil
I just paint mine with cast blast and take the 1-2 point hit. Chuck
Chuck Gongloff is offline   Reply With Quote
Old 04-21-2006, 01:48 PM   #8
yellow71
CF Senior Member
Thanks guys. I appreciate the responses.
Regards
Neil
Old 04-24-2006, 07:33 AM   #9
corvetteload
CF Senior Member
corvetteload's Avatar
Do you think they didn't rust from the factory?!?!?!? Be realistic and don't be so anal about trivial stuff like surface rust. Drive the car and tell those judges to stay the "F" away from your car..................B
corvetteload is offline   Reply With Quote
Old 04-24-2006, 11:04 AM   #10
Greg Gore
CF Senior Member
Greg Gore's Avatar
Quote:
Not all Corvette enthusiasts are interested in driving their cars all the time. Some of us prefer to learn how to do factory correct resto and to compare our work with some of the best skilled and most recognized restorers in the country afterwards to see how close we can get. Getting a from one of those guys is an honor that many will never taste.
Old 04-24-2006, 01:25 PM   #11
yellow71
CF Senior Member
Why are you reading the "Factory Correct Resto" forum? Was that blower sticking thru your hood on the option sheet in the mid 70s?
Each to his own.
Regards
Reload this Page Whats the trick?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ok, whats the latest on clutches for blown vettes? BlackMagicC5 C5 Forced Induction/Nitrous 22 06-09-2004 12:58 AM
whats the easiest way to set the timing? Wheelman C4 Tech/Performance 11 12-06-2001 07:09 PM
Whats the deal with Vortec Heads TTop Tony C3 Tech/Performance 21 08-08-2001 04:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
