Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-13-2006, 01:00 AM   #1
mdj21
CF Senior Member
mdj21's Avatar
Default partial VIN numbers
in 1973, would the partial VIN number on the transmission be the exact same partial VIN number stamped on the engine block?
mdj21 is offline   Reply With Quote
Old 04-13-2006, 08:40 AM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Yes, provided the engine and tranny are original. The partial VIN (consecutive unit number) on each should also match the the consecutive unit number on the full VIN tag on the driver's windshield post.
Easy Mike is offline   Reply With Quote
Old 04-13-2006, 09:35 AM   #3
mdj21
CF Senior Member
mdj21's Avatar
is the consecutive unit number just the last 6 digits of my VIN?
what about the first three digist of the partial VIN? would those be the same between engine and trany?
for example, on my transmission the number is 13Sxxxxxx (where the x's are the last six digits of my VIN. would the engine block partial VIN also start with these same three numbers and letters, 13S?
Old 04-13-2006, 12:23 PM   #4
Easy Mike
CF Senior Member
Easy Mike's Avatar
Consectutive Unit number is usually the last five digits of the VIN since they have never made 100K Corvettes in a single year of production. The first digit of the full length six digit consecutive unit number is always the same for the entire model year so each vehicle assembled during that production year has this digit. For '73, it's a 4; for '72 is was a 5; a 7 in '69.
The partial VIN stamps on the engine, tranny, and frame would all match since they were all done by the same worker using the same tool at the same work station on the assembly line. This worker set the tool with the correct sequence of digits, then stamped the engine, tranny, and the frame (in two places). After stamping and while the frame moved to the next workstation, the worker reset the tool with the VIN of the next Corvette on the line.
13S is a prefix code indicating Chevrolet Division of General Motors (1), the model year (3), and the plant code (S for St. Louis)
Old 04-13-2006, 12:58 PM   #5
mdj21
CF Senior Member
mdj21's Avatar
i could have sworn that the number off of my transmission had all six numbers from my vin, but i don't have it in front of me to verify and my guess is that you are probably right.
thanks for the info. very interesting.
my original motor is long gone, but cralling under the car to work on a speedo issue, i noticed the partial VIN on the transmission and was just wondering if my original motor would have had the exact same number on it. thank you for satisfying my curiosity.
so what two locations on the frame is the VIN stamped? are you counting the plate on the windshield pilar as one of them?
thanks again,
Mike.
Old 04-13-2006, 04:16 PM   #6
JohnZ
CF Senior Member
Support Corvetteforum!
The VIN derivative is stamped in two locations on the frame. One is centered over the front edge of the #4 body mount bracket, and the other is about 12" forward of the rear kickup, about where your wallet is when you're seated in the car; both are about 1/4" inboard of the outer edge of the frame rail. The one at the rear can be seen with a small mirror, the forward one can't be seen with the body on.
JohnZ is offline   Reply With Quote
Old 04-13-2006, 04:34 PM   #7
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
It might have all six digits. I'm trying to remember what's on mine, all six or the last five. Likewise, it's been a long time since I crawled under there.
Quote:
....my original motor is long gone, but cralling under the car to work on a speedo issue, i noticed the partial VIN on the transmission and was just wondering if my original motor would have had the exact same number on it...
Yes. Engine and tranny would have the same stamps.
Old 04-13-2006, 05:43 PM   #8
mdj21
CF Senior Member
mdj21's Avatar
thanks, guys.
Reload this Page partial VIN numbers
Tags
c3, codes, corvette, decoder, engine, frame, location, locations, number, numbers, partial, stamping, transmission, vin, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Matching numbers? Err...almost...? 74FLCONV C3 General 10 04-09-2005 08:01 PM
Non-matching numbers engine USA SHARK C3 Tech/Performance 12 08-23-2003 05:10 PM
Correct numbers on motor? 467-Ratman C3 Tech/Performance 30 01-14-2002 09:07 AM
Need Help--GM Offering "Partial" New Engine qwikz06 C5 Tech 14 11-02-2001 11:49 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
