Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-04-2006, 01:03 AM   #1
jroyse
CF Member
Default 79 rocker covers-chrome or painted?
need restoration info for 79 engine. how do I find out the finish is for engine exterior parts? Brackets, shields, bolts, etc.
jroyse is offline   Reply With Quote
Old 04-04-2006, 02:16 AM   #2
BanGnGearS
CF Senior Member
BanGnGearS's Avatar
I believe that the original covers for a 79 L-82 are just the rough aluminum look.. b4 i did mine they were sprayed black.. im really not to sure, but if you take you time with them you can polish them to a chrome finish.
BanGnGearS is offline   Reply With Quote
Old 04-04-2006, 03:03 AM   #3
KapsSA
CF Senior Member
KapsSA's Avatar
Check out this thread.http://forums.corvetteforum.com/show....php?t=1306741
78s pretty much the same as 79s. L48 valve covers and intake manifold painted engine blue.
Mike
KapsSA is offline   Reply With Quote
Old 04-04-2006, 07:37 AM   #4
fl_rider
CF Senior Member
fl_rider's Avatar
Default Not totally stock...
This should help
__________________
1978 - GMPP 350 / 290 - Flowtech Headers - 2-1/2" Stainless Duals
Mahogany - Light Beige
Click here for pictures
Chris B
If they weren't meant to be driven they wouldn't have wheels.
fl_rider is offline   Reply With Quote
Old 04-04-2006, 09:42 AM   #5
paul 74
Ontario, Canada
Support Corvetteforum!
paul 74's Avatar
Covers (L-82) are aluminum, painted black with bare ribs. Chrome air cover and black master cylinder cap are not correct.
paul 74 is offline   Reply With Quote
Old 04-04-2006, 10:21 AM   #6
G dad
CF Senior Member
G dad's Avatar
Location: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I put it back together just the way I found It...Never touched before me... not a great shot though it may give you some idea of how it should look
G dad is offline   Reply With Quote
Old 04-04-2006, 10:43 AM   #7
jroyse
CF Member
Default 79 valve covers
pictures will really help.
Thanks for the response
Old 04-04-2006, 01:17 PM   #8
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
No chrome. Base engine valve covers were painted engine color; optional L-82 valve covers were painted flat black with natural metal ribs (good examples of each in the pix). For underhood bolt and other part finishes, I would trust the NCRS Judging Guide for '79.
Easy Mike is offline   Reply With Quote
Old 06-01-2006, 01:56 PM   #9
C3 4ME
CF Senior Member
C3 4ME's Avatar
Is that an aluminum water pump, or is it cast iron painted silver, and what would be correct for a 79 L-82? My whole engine just got doused in black (except for the intake) when the previous owner had it rebuilt.
C3 4ME is online now   Reply With Quote
Old 08-21-2006, 03:30 PM   #10
79corvetteowner
Junior Member
Default i need chassis specs!!
I recently purchased a 79 stingray corvette and learned that the previous owner ran it off the road and into a ditch. the big problem is the frame was bent out of shape and i dont know the factory measurments of every section of the frame, if anybody has access to this information, if you could you pass this information on to me it would be appreciated.
79corvetteowner is offline   Reply With Quote
Reload this Page 79 rocker covers-chrome or painted?
Tags
a1979, corvett, covers, painted, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
What crazy mods do you want to do to your vette? CDaniel525 C3 Tech/Performance 28 11-28-2001 02:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
