Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-06-2005, 01:12 AM   #1
emf1367
Junior Member
emf1367's Avatar
Default 1975 Control Arm Shaft finish?
I'm restoring my car to factory specs and need to know from someone that has an original car if the control arm (A-Arm) shaft is painted or natural finish. The NCRS manual is specific about the finish on the Control Arm, bolts, and retainers but doesn't specify the shaft. Does anybody know for sure?
Thanks in advance for your assistance.
emf1367 is offline   Reply With Quote
Old 07-12-2005, 06:32 PM   #2
emf1367
Junior Member
emf1367's Avatar
Through all of my research I found that my car came with black painted control arm shafts. I also learned that there were cars in earlier and later years that came with natural finishes.
Old 07-12-2005, 08:31 PM   #3
MEGALADON
CF Senior Member
MEGALADON's Avatar
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
MEGALADON is offline   Reply With Quote
Old 07-13-2005, 11:04 AM   #4
NHvette
CF Senior Member
NHvette's Avatar
From the Prince Restoration Guide ... section on 73-77:
Control arm cross shafts are painted semi-gloss
black on some cars and unpainted on others. Cars with
painted cross shafts typically have control arm bush-
ing retention washers and bolts that are also painted
semi-gloss black. Cars with unpainted cross shafts typ-
ically have retention washers that are gray phosphate
plated and bolts that are black phosphate plated.
Most of the ones I have seen are just plain rusty.
Maybe they had paint at one point - probably not.
I recall my 75 retention washers did not appear painted.
NHvette is offline   Reply With Quote
Old 07-27-2005, 02:47 AM   #5
emf1367
Junior Member
emf1367's Avatar
Thanks for the additional info about the retention washers. Yeah, all of my washers and bolts were unfinished except one was yellow cad plated; obviously it was an aftermarket replacement. The unfinished ones were slightly rusted but mainly just dirty.
Reload this Page 1975 Control Arm Shaft finish?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
