Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-14-2005, 11:51 PM   #1
71will
Junior Member
71will is offline   Reply With Quote
Old 07-15-2005, 08:45 AM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Everything you want is in the assembly instruction manual (AIM), including the original part numbers and how the vents were installed. Order an AIM. If the previous owner actually glassed over the old in order to install the newer, you may want to consider replacing the fenders. That task might be easier and give better results than trying to undo the prior 'glassing. Good luck.
Easy Mike is online now   Reply With Quote
Old 07-18-2005, 11:10 PM   #3
71will
Junior Member
I didn't think of the AIM which I have. I looked at it but the drawing is obscure. The fiberglass looks like from the inside fender should peel off with only slight damage. It needs a complete paint anyway.
Will
Old 07-19-2005, 08:10 AM   #4
early shark
CF Senior Member
71will:
There is a horizontal ledge (lip) that extends inward on the top and bottom edges of the openings. These bottom ledges have a built in metal clip that contains the single threaded stud that protrudes from the center bottom of the side louver piece that inserts in the openings. A shouldered captured nut is used to thread on to the stud.
The upper ledge has two holes that metal clips are inserted onto and a screw attaches thru the side louver and into the upper ledge with metal clip.
There are only three attaching points for each side louver.
early shark is offline   Reply With Quote
Old 07-19-2005, 08:24 AM   #5
71will
Junior Member
thanks. I know see those ledges i thought they were paart of the "custom" repair. I'll let you know how it goes.
Will
Reload this Page 70-72 Air Vent placement
Tags
air, placement, vent
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
