Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-08-2005, 02:46 PM   #1
Falcon05Dad
CF Senior Member
Falcon05Dad's Avatar
Default '64 4sp Shifter Issue - Requesting Opinions
For you midyear owners:
My '64 365hp Coupe with its stock 4 speed shifter is now more than occasionally locking up in two gears when backing up and then shifting from reverse to first. I've adjusted the shifter and the linkage per the manual without the problem improving much. I'm tired of crawling under the car to free it up, so I think it's time for a replacement. I'd like your opinion whether I should first replace just the linkage pieces (rods, adjusters, and clips) or bite the bullet and buy a new repro stock shifter as well.
Thanks.
Greg
Falcon05Dad is offline   Reply With Quote
Old 07-08-2005, 06:48 PM   #2
hdvettes
CF Senior Member
hdvettes's Avatar
Take the shifter out and disassemble it. Then squeeze the main case back together. It is spread open and it lets the shifter handle slip between the shifter arm plates. Eliminate the gap and it will work fine again.
Mike
hdvettes is offline   Reply With Quote
Old 07-11-2005, 01:01 PM   #3
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Keep your original and rebuild it.
Easy Mike is offline   Reply With Quote
Old 07-11-2005, 01:24 PM   #4
Falcon05Dad
CF Senior Member
Thanks, gents! I'll give it a shot.
Greg
Reload this Page '64 4sp Shifter Issue - Requesting Opinions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
