Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-08-2005, 02:47 AM   #1
mstanton
CF Senior Member
mstanton's Avatar
Default Carb Date
I've been looking for a carb for my 70 LT-1. It is a Feb build car with engine stamp of 0203. What would be the latest date that would be considered "correct".
mstanton is offline   Reply With Quote
Old 06-08-2005, 09:10 AM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
A correct date for your carburetor would be dependent upon the build date of your Corvette, not the engine assembly date. Each date (engine assembly date and carb date) should precede the build date of your LT-1 by no more than six weeks (most common span) and no less than three weeks. This allowed the necessary parts needed to assemble your LT-1 to be manufactured, shipped to St. Louis, and on hand by the date your car started down the assembly line. If your engine is coded February 3, your carb date ought to be about the same but not necessarily match. Your LT-1 could be expected to have a mid March build date if the six week time span is used. These are very general guidelines, but common. Lots of things could have occurred to to affect the dates.
Easy Mike is offline   Reply With Quote
Old 06-08-2005, 01:44 PM   #3
wildman378
CF Senior Member
wildman378's Avatar
I think it's 6 months prior to the build date not 6 weeks but I'm not 100% sure on that.
wildman378 is offline   Reply With Quote
Old 06-08-2005, 03:23 PM   #4
JohnZ
CF Senior Member
Support Corvetteforum!
From a judging perspective, dated components get full credit up to six months prior to the car's final assembly date; two to six weeks is more "typical", but you're allowed up to six months.
JohnZ is offline   Reply With Quote
Old 06-10-2005, 12:54 AM   #5
mstanton
CF Senior Member
mstanton's Avatar
Thanks for the replies. They are exactly what I needed to know. The build date on my trim tag is Feb 23. So I guess a carb as late as the first or maybe second week of Feb should work.
Old 06-13-2005, 11:44 AM   #6
ctjackster
CF Senior Member
ctjackster's Avatar
Send a message via AIM to ctjackster
Quote:
key off of the final assembly date per VIN-derived birthday, rather than the body built date from the T Tag
ctjackster is offline   Reply With Quote
Old 06-15-2005, 11:15 AM   #7
early shark
CF Senior Member
Your best bet would be to get a look at the '70 LT-1 registry done by the NCRS member and compare other known LT-1 cars with original carburetors and cars with similar build dates. See what dates are on these cars and then proceed to locate a properly dated carb.
Probably at Bloomington or Carlisle would be a good place to chat with other LT-1 owners and see their cars.
early shark is offline   Reply With Quote
Old 06-15-2005, 02:51 PM   #8
mstanton
CF Senior Member
mstanton's Avatar
Where do I get a copy of the NCRS LT-1 Registry?
Old 06-15-2005, 05:53 PM   #9
hdvettes
CF Senior Member
hdvettes's Avatar
Do not go by the cars assembly date. You must go by the engine assembly date. You might find a carb that will fit the car but not the engine assembly. If the engine sat in inventory before going into a car the dates may fall way before the car was assembled. Dated parts always preceed the assembly they go into.
Mike
hdvettes is offline   Reply With Quote
Old 06-15-2005, 06:06 PM   #10
mstanton
CF Senior Member
mstanton's Avatar
Was the carb put on the engine when the engine was assembled at Flint or when car was put together in St. Louis?
Old 06-16-2005, 10:30 AM   #11
ctjackster
CF Senior Member
ctjackster's Avatar
Quote:
Mike
no, carb was not put on engine as part of the assembly that took place before the "engine assembly date" per the pad. Verified info. Drop dead date for carb would be the birthday, but carbs were binned items and also not the last thing installed on the final line, so carb dates 2-6 weeks preceeding BIRTHDAY are typically found, I believe.
Old 06-16-2005, 01:16 PM   #12
Easy Mike
CF Senior Member
Easy Mike's Avatar
None of the Corvette engines leaving Flint had carburetors installed; all were added at St. Louis.
Reload this Page Carb Date
Tags
assembley, carburetor, date, engine
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with a carb date polyrocks C1 & C2 Corvettes 13 11-10-2002 09:49 PM
[EVENT]OK Date is set for Delaware Trip Mr Mojo Northeast 78 05-30-2002 12:11 PM
Which carb is better, Holley or Demon?? damac C1 & C2 Corvettes 24 11-28-2001 11:56 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
