Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2005, 04:08 AM   #1
RRod
CF Senior Member
RRod's Avatar
Default 1965 New Leather Seat Covers Question
I had the interior redone on my 1965 Conv by a shop that does a lot of NCRS restoration here locally. Although the new leather seat covers (with new foam, burlap, etc) look great, they continue to emit a very unpleasant odor over three months later that overpowers any new leather smell (I can't smell any new leather at all). Is adhesive used on seat restorations? I also had new carpeting installed, but the odor seems to be strongest from the seats themselves ... it smells like adhesive but maybe it's the new burlap?
I also lost about 1-1/2" of needed head room. Are the center inserts supposed to be flush with the side bolsters like mine appear to be? As I recall, I thought the center inserts were supposed to be depressed somewhat on new restorations (either by fillament ties to pull down the insert or by the proper shape of the foam).
The car is due back to the shop next week for some other other work and I was planning to talk to them about the odor and head room if this is not normal.
Thanks!
RRod is offline   Reply With Quote
Old 06-07-2005, 02:22 PM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Did you install new seat foam? Adhesive may have been used on new seat foam. The actual upholstery should not have needed adhesive. It certainly won't hurt to ask what was done when you take the car back to the shop.
Easy Mike is offline   Reply With Quote
Old 06-07-2005, 02:41 PM   #3
JohnZ
CF Senior Member
Support Corvetteforum!
The seat contours look excellent - the headroom issue is likely a result of the new (stiffer) foam buns, which will soften over time. The adhesive "aroma" is probably related to the carpet installation, as little or none is normally used in the seat build-up.
JohnZ is offline   Reply With Quote
Old 06-07-2005, 03:30 PM   #4
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
Originally Posted by JohnZ
The seat contours look excellent - the headroom issue is likely a result of the new (stiffer) foam buns...
Old 06-08-2005, 01:45 PM   #5
65convt
CF Senior Member
65convt's Avatar
I agree with the odor problem coming from adhesive used on the carpet. I had a slight odor when I did the interior in my 65 convt. last year. But that only lasted a few days.
As for the headroom problem, I have the same problem with the seats in my 65 coupe. Just did them and with the new foam I also have a clearance problem. I'm 6' and my head just hits the headliner. I'm sure the seats will settle in time.
65convt is offline   Reply With Quote
Old 06-08-2005, 03:45 PM   #6
RRod
CF Senior Member
RRod's Avatar
Thanks to everyone above for the help and info.
I'll ask the shop about why the heavy odors still after 3 months. Maybe they used the wrong adhesive or something. I wish I could smell the new leather.
Reload this Page 1965 New Leather Seat Covers Question
Tags
cover, leather, odors, seats
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
