Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-30-2005, 07:58 PM   #1
hankhenry
Junior Member
Default Goodyear Eagle GT 255/60/15
I have two sets of Goodyear Eagles, one set has TPC SPEC.1032 on the sidewall under the tire size and the other set does not.
Is there any truth that the set with the TPC SPEC.1032 on it is from the factory and the one without are tires sold through Goodyear dealers as a replacement.
Also would the tires without the TPC SPEC.1032 be correct for a 81 corvette.
Would it make any difference if the car was being judged like at the Bloomington Gold event with these tires on.
HH
hankhenry is offline   Reply With Quote
Old 06-27-2005, 01:35 PM   #2
Jon S
CF Senior Member
Jon S's Avatar
HH
Just saw your post - My '81 Vette has the original factory installed Eagle GTs and they do have the TCP SPEC 1032 on the sidewalls. Replacement I bought through Goodyear store (for an extra) does not have the TCP SPEC on the sidewall. Since no one makes WOL Eagle GTs, I do not believe it would make any difference re: Bloomington as long as all four on the car are the same. i.e. - do not mix TCP SPECs with non TCP SPECs. Do you have any "extra" GTs you would consider parting with? Let me know. Thanks.
Jon S
Jon S is offline   Reply With Quote
Old 06-27-2005, 01:38 PM   #3
Jon S
CF Senior Member
Jon S's Avatar
If you have 4 good TCP SPES tires, I would use them for Bloomington. (Hope you were not referring to this past weekend's meet. If so, sorry I did not respond sooner.
Jon S
Old 06-27-2005, 02:51 PM   #4
JohnZ
CF Senior Member
Support Corvetteforum!
The "TPC" spec stands for "Tire Performance Criteria", which is a set of performance standards GM issued to the OEM tire manufacturer based on that manufacturer's advance tire submission passing the GM tests to qualify it as an original-equipment tire. That ID is required on tires originally supplied to assembly plants for OEM use, but is seldom seen on replacement tires, as they are not the same construction as the OEM tires (although they may look the same).
JohnZ is offline   Reply With Quote
Old 07-05-2005, 11:52 PM   #5
hankhenry
Junior Member
I want to thank everybody that replied, now i just have to figure out what to do.
As luck would have it if i pick the best four tires i will end up with 2 with
the TPC spec and 2 without.
Well somehow i will figure it out and then decide what to do with the other eagles.
Thanks again.
HH
Old 07-28-2005, 09:55 PM   #6
Jon S
CF Senior Member
Jon S's Avatar
Thanks again.
HH
Please send me a Personal Message when you decide what you want to do with the other eagles. Thank you!
Old 08-01-2005, 09:46 AM   #7
Paul Borowski
CF Senior Member
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Paul Borowski's Avatar
hankhenry, if I'm remembering this correctly, the "replacement" ones will have that "safety warning" embossed on them like newer tires do that I believe originals didn't. Also, original tires have a pretty clearly defined date on them. I haven't been able to decipher the date code on newer "replacement" GT tires. Originals will be dated in a "depressed molded" area that looks like an oval or racetrack. Usually it's a four digit number that reads like "0121", which in this case would be 12th week of production, 1981. Another example would be 0042, or 4th week of production, 1982. I do not think this would really hurt that much for Bloomington type judging, as long as you had four matching tires, but for like NCRS Bowtie type judging, where the tires are judged for "Originality", then it would matter.
__________________
If Health Food Was Delicious, There Wouldn't Be So Many FAT People
Paul Borowski, Massillon,Ohio NCRS # 26140
1968 International Blue/Dark Blue Vinyl L-79 327/350hp 4spd Convertible
1974 Orange/Saddle Leather L-48 350/195hp Automatic Coupe
Paul Borowski is offline   Reply With Quote
Old 10-17-2005, 05:36 PM   #8
Hurricane103
Junior Member
undefinedI was reading through the threads and saw the Goodyear Eagle GT question. Where can I find the going rates on OEM tires? I have a set of brand new Eagle GT 255/60/15s that I've been storing on rims in a controlled enviroment, (on a rack in my 65 degree, 55% humidity basementon ) from a project car gone bad twenty something years ago.
Hurricane103 is offline   Reply With Quote
Old 10-17-2005, 07:24 PM   #9
Jon S
CF Senior Member
Jon S's Avatar
Quote:
Please send me an e-mail to dumpster900@yahoo.com. There is no "going rate" on these tires. Let me know where you are located in the e-mail. Thanks!
Reload this Page Goodyear Eagle GT 255/60/15
Tags
15, 255, 25560, 2556015, 60, eagle, goodyear, gt, gts, sale, sizes, spec, st, tpc, wol
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Goodyear Eagle GT II? Skyhigh82 C3 Tech/Performance 10 12-14-2003 02:37 PM
WTB: Goodyear Eagle GT tires, 255 / 60 R15 outline white letters NASCAR314 C3 Parts for Sale/Wanted 10 08-02-2002 11:19 PM
H.P. Street/Autocross Tires; Goodyear Eagle GT 2's or BFG Radial T/A's? GG's70YellowConv C3 Tech/Performance 16 01-22-2002 01:12 AM
Sorry...I meant to say: Will 255 60 15 tires fit on a '75? 75SHARK C3 Tech/Performance 17 11-07-2001 05:38 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
