| Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition |
05-24-2005, 01:29 PM
CF Senior Member
Color of 69 rocker panels
I have semi-flat black and semi gloss back(50-60%) and I'm not sure which one would be correct for the lower rocker trim panels.
Thanks!
Greg
05-24-2005, 02:39 PM
CF Senior Member
Cruise-In II Veteran
Semi flat. Krylon 1215 (might be 1218) semi flat black is an almost perfect match.
05-24-2005, 03:15 PM
CF Senior Member
Thanks!
I have quarts mixed up in both of these. The semi-flat I have is about 20% gloss.
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
