Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2005, 06:56 PM   #1
RichF
CF Senior Member
St. Jude Donor '03, '04 & '05
Support Corvetteforum!
RichF's Avatar
Default Any sites to "share" VIN/ engine info?
Hi:
I'm trying to track down the car my 427 was in originally .... I have the last 6 digits from the engine (that relate to the VIN of the car) and believe it to be original stamping. My '66 was originally a small block car that was converted to BB [before I bought it] .. and the 427 came from a later car, and I wonder if that car is still out there .... I've been looking in the NCRS Driveline and at the 63-67 registry site... any other sites that you folks know of???
Rich
RichF is offline   Reply With Quote
Old 04-10-2005, 08:44 PM   #2
JohnZ
CF Senior Member
What does the VIN stamping on the pad read? Should be a minimum of seven digits. How about the engine plant stamping?
JohnZ is online now   Reply With Quote
Old 04-10-2005, 09:47 PM   #3
RichF
CF Senior Member
RichF's Avatar
Hi John:
Sent you a PM ....
Old 05-18-2005, 10:45 AM   #4
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
The pad at the front of the right head should have two stampings. One will be the engine code and should contain a T for Tonawanda. It will tell you the date of assembly (month and day, not year) and the original application for the engine (manual trans, auto trans, horsepower rating, etc.). The second number will be comprised of the assembly plant code (S for St. Louis) and five or six digits of the original vehicle's VIN. With plant code and engine code you should be able to get a pretty good handle on the identity of your big block.
Easy Mike is offline   Reply With Quote
Reload this Page Any sites to "share" VIN/ engine info?
Tags
share, vin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
