Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-27-2005, 03:22 PM   #1
R1234
CF Senior Member
R1234's Avatar
Default a.i.r. tube I.D. ?
Hello,
I have a couple of exhaust air tubes that I think are from a 74 big block. Anyone out there that can identify these for sure?
Thanks in advance.
Bryan
R1234 is offline   Reply With Quote
Old 03-28-2005, 11:15 AM   #2
mayberg
CF Senior Member
mayberg's Avatar
They don't look big-block to me. The two middle cylinders aren't that close together.
__________________
Send Me your 1974 VIN number and info: PS, PB, PW, Tilt, AC, int/ext color, leather/vinyl, etc.
mayberg is offline   Reply With Quote
Old 03-28-2005, 02:43 PM   #3
JohnZ
CF Senior Member
Support Corvetteforum!
Those are small-block tubes.
JohnZ is offline   Reply With Quote
Old 03-28-2005, 11:23 PM   #4
R1234
CF Senior Member
R1234's Avatar
Hello guys,
Are they correct for a 68? The catalogs list the small block tubes as 68-74. So, I'm assuming they all look alike.
Which ones the driverside and which ones the passenger?
Bryan
Old 03-29-2005, 10:29 AM   #5
Paul Borowski
CF Senior Member
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Paul Borowski's Avatar
Bryan, I just looked at my 42,000mi "very original" Silver '68 coupe and those look quite different than mine. For one thing, on the passenger side of my '68, the main vertical pipe is very short, about 1/3 of what is shown on those two. Also the one that has the longer horizontal cylinder is not what is on my car. Mine also do not have those "45 degree angle bends" on the smaller tubes like the one side depicts.
Keep in mind for the smallblock C3s that did come with A.I.R., those tubes came in a few diffrent styles. I just know those shown are a bit different than what is on my original '68.
__________________
If Health Food Was Delicious, There Wouldn't Be So Many FAT People
Paul Borowski, Massillon,Ohio NCRS # 26140
1968 International Blue/Dark Blue Vinyl L-79 327/350hp 4spd Convertible
1974 Orange/Saddle Leather L-48 350/195hp Automatic Coupe
Paul Borowski is offline   Reply With Quote
Old 03-29-2005, 10:30 AM   #6
mayberg
CF Senior Member
mayberg's Avatar
Each manifold in your pictures above appears to be for the driver's side.
I would assume they all look alike also, since the small-block exhaust manifolds are pretty much the same.
Old 03-29-2005, 11:59 PM   #7
R1234
CF Senior Member
R1234's Avatar
Paul,
Thank you for the pictures. I had a hunch these were not correct for 68. Hmmm, I wonder what these do fit. I can't find a part number on them. Do the repo's in the catalogs look anything like the 68 tubes?
Mayberg,
With the check valve tubes pointing toward the front of the engine that would make sense as to these being driverside tubes. But they sure don't look alike. I wonder if they are for 74 and later cars?
Bryan
Reload this Page a.i.r. tube I.D. ?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
86 with a miss continued... Dale1990 C4 Tech/Performance 33 03-17-2004 11:00 PM
L98 owners: Can I remove my A.I.R. diverter valves/solenoids without getting any codes? CentralCoaster C4 Tech/Performance 12 09-23-2003 03:41 PM
A.I.R. Pump Eliminator??? ZAD54 C4 Tech/Performance 37 05-29-2002 01:07 PM
Does a 76 L82 require an A.I.R. system, or is that only a Calf. thing. 76greg C3 Tech/Performance 9 01-29-2002 04:40 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
