Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2005, 12:00 PM   #1
R1234
CF Senior Member
R1234's Avatar
Default A.I.R. smog tube question
I was looking thru one of the Camaro parts catalogs and came across the 67/68 small block A.I.R. replacement tubes. The catalogs reads exact reproductions. The tubes from the pic look exactly the same as the 68 thru 74 Corvette small block replacemnt tubes. Are they?
Bryan
R1234 is offline   Reply With Quote
Old 03-05-2005, 01:52 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
Nope - the exhaust manifolds and A.I.R. tubes are a completely different design on the Camaro than on the Corvette; the Camaro uses "log" manifolds and the tubes enter at an angle, and the Corvette uses "ram's horn" manifolds and the tubes enter horizontally.
Here's the Corvette manifold and tubes:
And here's the Camaro manifold and tubes:
JohnZ is online now   Reply With Quote
Old 03-05-2005, 02:11 PM   #3
R1234
CF Senior Member
R1234's Avatar
Thanks John for the answer and the pics.
Bryan
Reload this Page A.I.R. smog tube question
Tags
air, smog, tube
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
What should I do to get more power? Corv3tteFAN C3 Tech/Performance 18 08-11-2004 03:09 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
