01 Trans AM | Twin Turbo | Fikse Aros | Fuel Cell | Bult T56 | E85
Kicking around the idea of selling the car to invest and pay off some debt. Car doesn't get driven as much as it should. Sits in the garage most of the time, I rarely have time for it anymore with everything else going on in my life. If it doesn't sell no biggie.
I will list the important info on the car. I'm honest about everything. The only bad things I can think of are that the gas gauge is not working (easy change in hp tuners). Heat works, but A/C blows hot. Previous owner said it needs a new compressor, I never tried to fix it as I don't use it anyways. ABS light is on also. Dont know problem. ABS does work though. E-Brake doesn't work.
The car runs and drives great. It's a blast to drive. Turbos are loud as hell even at idle. Gets looks everywhere. I bought the car in August last year. I've driven it to work and back 40 minutes each way with no hiccups. Never heats up, even in stop & go traffic in 100+ degree weather.
The car has 85K miles on it - the turbo kit, built motor, etc. all have 9K miles...
Car has just been retuned on 15lbs on e85, haven't gotten any numbers on it yet. My guess on 15lbs is around 800whp. I can have it dyno'd if need be.
The black exterior is damn near flawless. Interior is perfect as well, all untouched.. Car still has heat, and A/C, back seats etc...
Asking $25K, clean title in hand.
Serious enquiries only. Please don't waste my time. No joy rides. No tire kickers.
Email: ericbuffs55 AT gmail DOT com or Text me anytime at 8O6-23.1=62.34
Modifications
---Engine---
9.0:1 CR
Stock aluminum block LS1 (5.7L), bored .010 over (348 ci)
Polished crank and fully balanced rotating assembly
-16cc Mahle forged pistons
Eagle 4340 forged H-beam connecting rods w/ ARP L19 bolts
Clevite bearings throughout
Ported and polished 5.3 heads (heads/valves have 3000 miles)
ARP head studs
LS9 head gaskets
Comp Cams 220/224 .564/.568 115 lsa, custom turbo grind cam
LS2 timing chain
LS6 ported oil pump
Edelbrock Pro Flo Intake
90mm Throttle body
Patriot Performance Gold dual springs, with titanium locks and retainers
LS7 lifters
NGK BR7EF plugs
MSD wires with coil relocation under radiator
Black painted valve covers with welded on -12 AN bungs
Custom catch can setup
---Turbo Kit---
58mm Precision turbos, T4 .81 AR exhaust housings.
Custom built, thick walled stainless steel log manifolds
3 Stainless steel downpipes, merged into 4 stainless exhaust, then dumped before the axle
Custom aluminum coldside - 2" from turbos to intercooler - 4" from intercooler to TB
Polished 27" x 12.5" x 3.5" intercooler
(2) 38mm Tial wastegates
(2) 50mm Tial Blow-off valves
---Fuel System---
Fuel system good for 1100 whp on E85
Custom fabbed 25 gallon fuel cell by DBRODS Speed & Chassis
90 ohm summit fuel sending unit
-10 AN black braided Earls nylon feed line
-8 AN black braided Earls nylon return line
Injector Dynamics ID2000 injectors
Aeromotive 13110 - Pro-Series EFI Regulator
All black Earls fittings
Magnafuel 4303 Fuel Pump
Aeromotive billet pre/post fuel filters
---Suspension---
Custom welded "in-floor subframe connectors (2x4)
BMR tubular K-member
BMR tubular upper A arms
BMR tubular lower A arms
BMR tubular rear lower control arms
BMR tubular panhard bar
BMR rear lowering springs
BMR adjustable torque arm
BMR tubular Torque Arm Relocation Crossmember
Strange single adjustable coilovers in front with 300lb springs
Strange single adjustable shocks in rear
Polyurethane motor mounts
Polyurethane trans mount
---Drivetrain---
Stage 2 Built T56 6-speed
RPS Twin Disc cluth (Entire clutch assembly with flywheel weighs 27lbs).
MGW Shifter with custom cobra ****
3.5" aluminum driveshaft
Moser 12-bolt rear end
Detroit True-trac differential w/ 3.08 gears
---Wheels/Tires---
Fikse Aros - 17x9.5 fronts | 17x11 rears
M&H 325/45/17 DRs in rear
Nitto NT555 275/40/17 fronts
---Brakes---
Drilled/slotted rotors
Ceramic pads
---Miscellaneous---
Full A/C, heater, etc. all stock accessories are kept in stock location
A-pillar 3 gauge pod wideband o2 (a/f), fuel (psi), boost/vacuum (psi/hg) and eboost2 electronic boost controller in the left vent
Original US Exotics Superhawk fiberglass hood (1 of 5 made)
Custom 3-bar speed density tune on e85
Battery reloation to the rear
Custom mesh license plate cover
Modifications
---Engine---
9.0:1 CR
ARP head studs
LS9 head gaskets
LS2 timing chain
LS6 ported oil pump
90mm Throttle body
LS7 lifters
NGK BR7EF plugs
---Turbo Kit---
---Fuel System---
---Suspension---
---Drivetrain---
---Wheels/Tires---
---Brakes---
Ceramic pads
---Miscellaneous---
