F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
(socal) FS/ft 1999 Camaro z28 h/c/tuned
Old 02-09-2013, 11:49 PM
MJs1fastSS
MJs1fastSS's Avatar
Default (socal) FS/ft 1999 Camaro z28 h/c/tuned
1999 Camaro Z28
Performance:
Ls1 346c.i. 5.7L Short block 140k
PRC Stage 2.5 5.3L CNC Ported Heads
Prc .650 dual springs
TSP Magic Stick 3 237/242 .603"/.609"
Cometic gaskets
Professional Products Red fuel rails
F.A.S.T. 36# Precision Flow Injectors
LS6 Intake manifold
BBK 85mm Throttle Body
SLP 85mm MAF & harness
SLP smooth bellow
No EGR
NO AC (have it complete and packaged and will go along with the car)
Pacesetter Ceramic Long tube Headers 1 3/4"
TSP Off-Road ORY (no cats)
Fabricated Borla Adjustable Catback (2 out the left)
LS2 Timing Chain
LS6 Oil Pump
New GM LS7 Lifters
Chromoly Pushrods
ARP Head Bolts
Hypertech PowerStat 160 Thermostat
MSD wires with tr-55 plugs painted coil packs
SLP lid heated up to fit the 85mm maf
Transmission & Rear:
Ram powergrip Stage 3 Clutch Assembly
Aluminum Flywheel
Hurst shifter
Hurst Leather Shift ****
Skip Shift Eliminator
Master Cylinder Drill Mod
10 bolt with no noise what so ever
3.42 gear 4 channel traction control car
fresh fluid
Suspension:
Sam Strano Lowering springs
Koni Yellow Shocks/Struts
BMR Adjustable Torque Arm w poly bushing
BMR Lower Control Arms
BMR Subframe Connectors
BMR adjustable panhard bar
SLP strut tower bar
Wheels:
17x9 Chrome SS 10 spokes
255/40zr17 Michelin Pilot sports BRAND NEW
275/40zr17 Nitto Nt-05 Brand New
Brakes:
Baer Eradispeed 2 piece Front rotors
RotorPros Rear Rotors drilled and slotted
Duralast Gold Cmax Pads brand new
Painted Red brake calipers
Interior:
Tan Leather from 2001 Camaro Front and rear seats (no rips at all)
Swapped Ebony Interior plastics/seat belt guides, upper dash, ac/vents, center console for a two tone interior look.
Fosgate Speakers
NON SMOKER
Appearance:
painted Satin Berger panel
ttop car
deleted antenna
Car was tuned by Johnny @ dialed in performance and has a good amount of power for a daily driver 420rwhp and just at 410tq. Have all paperwork and receipts.
Title is clean, Arizona plates good until May 2013. Does not have any emissions on this car. And is the buyer’s responsibility to “know someone “ for CA smog. Has 140k on shortblock and just over 10k on top end miles will vary as this is one of my daily drivers
Price is 8,000 if it sells it sells if not i will still continue to enjoy it located in riverside ,ca. this car needs nothing and absolutely nothing wrong with it just kinda over the whole car scene. *** will trade for a silverado 03+ extended cad or crew depending on your truck +/- $
909 seven0520six 4
call or text
quick idle clip
http://www.keek.com/!TPzgbab
MJs1fastSS is offline
Old 02-15-2013, 05:50 PM
FrankieD
FrankieD's Avatar
Bump for a clean car with awesome mods..this should have been picked up by now.
FrankieD is offline
Old 02-15-2013, 07:20 PM
misscoman
misscoman's Avatar
misscoman is offline
Old 02-20-2013, 12:13 AM
MJs1fastSS
MJs1fastSS's Avatar
thanks fellas not yet ... i dropped the price to my bottom dollar 7,500. cheers
To (socal) FS/ft 1999 Camaro z28 h/c/tuned
Quick Reply: (socal) FS/ft 1999 Camaro z28 h/c/tuned
