F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
2014 LS7 engine option
Old 12-21-2012, 05:34 PM
Jinx
Jinx's Avatar
Yes, there's a gap that the LS7 Camaro fits nicely. And while the Z28 name seems conspicuously unused, SS 427 might have more marketability. It's probably the last 427, so they should make the most of it. Leave Z28 for something special in the next generation.
Jinx is offline
Old 12-21-2012, 05:41 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
Wow never thought of that. That would market great. SS 427 fender tag. I'd want one but wouldn't buy one lol
BeaZt is offline
Old 12-21-2012, 05:42 PM
Eric Reeves
Eric Reeves's Avatar
Ever wonder if they will reuse the LT5 designator again?
Eric Reeves is offline
Old 12-21-2012, 05:50 PM
Jinx
Jinx's Avatar
I think a few old-guard GM Powertrain engineers might like to see a new LT5, to remove some of the sting of "needing" help from Lotus back in the day. The rest of us would probably rather see that code retired. The LT5 is, after all, quite unique, no matter who gets the credit.
.Jinx
Jinx is offline
Old 12-21-2012, 06:51 PM
BuddhaZ06
BuddhaZ06's Avatar
i would love to see an lt5. if the lt1 is 450hp roughly, and the lt4 is roughly 650hp, i'd like to see a powerhouse lt5! maybe even dohc 6.2L with twin turbos! 750-800hp. oh man!
BuddhaZ06 is offline
Old 12-21-2012, 07:18 PM
RussM05
RussM05's Avatar
Received 1,012 Likes on 365 Posts
My guess is the LS7 will be made in very, very limited numbers and the buyer would have to know a high level person in GM to order one. I doubt you'll see one on the show room floor.
Perhaps as "off-road" only and not for street use. Kind of like the Camaro's in White for drag racing.
If you can get one, that would be an instant collector's item.
RussM05 is offline
Old 12-21-2012, 07:29 PM
John T
John T's Avatar
The LS 7 in the Vette was pushing 3200 LBS and would be pushing 500? lbs more..
My Z seemed so sensitive to weight that I am not sure that motor would keep the legend status that it earned pushing a Camaro body
John T is offline
Old 12-21-2012, 07:35 PM
hig4s
hig4s's Avatar
Originally Posted by JoesC5
1967 Corvette had 300 HP(base) with a curb weight of 3155#.
1967 Camero had a 375 HP L78(exact same L78 that was rated at 425HP when in the 1965 Corvette) optional engine, with a curb weight of 3375#.
The camero was the faster of the two.
Both the Corvette and the Camero survived to see 1968.
yes but there were optional engines in 67 available in the Corvette with ratings of 350hp, 390hp, 400hp and 435hp..
The base Camaro was a I6 and the base V8 was rated at 290hp, the most powerful V8 in a 67 Camaro was rated 400hp..
So I think it is valid to question why it appears there may be only a base level Corvette but more than one performance optioned Camaros with more power in that first year.
hig4s is offline
Old 12-21-2012, 09:25 PM
McGirk94LT1
McGirk94LT1's Avatar
Somehow I don't think that's how stuff works anymore. At least not for anything but uber exotics.
The copo drag camaro is limited because gm said they were going to be, but then turned around and made another years worth. Also, they arn't a "car", they are technically a part, with a part number I believe. I know none of them have VIN numbers.
McGirk94LT1 is offline
Old 12-21-2012, 09:31 PM
McGirk94LT1
Could be, and would make sense, but then again if it's lighter then the zl1 and has a perfectly tuned suspension, what the gt500 does to the zl1, the zl1 might do to this new Cameron's. That is that the zl1 beats it in the straights, but around the corners it's close, if not the lower level camaro takes it the win. Sorta like how the zr1/z07 behave as well.
However, I wonder if gm will stick a "428" badge on it this time around(sorry, just stirring the pot)...
Old 12-21-2012, 09:37 PM
Shurshot
Shurshot's Avatar
As I remember the highest HP in a 67 camaro was a 375 HP 396 BB. Same motor in the vette was rated at 425 HP
It had an aluminum head option but the HP stayed the same. You could get the M22 rock crusher transmission with it and 4:88 dealer installed gears.
Shurshot is offline
Old 12-21-2012, 10:02 PM
hig4s
hig4s's Avatar
There was the limited production 67 Z28 with dual four barrel carb option that had 400hp. Z28s in 67 were not listed in GM sales brochures. And I believe it was a souped up high reving 302 small block so it could compete in the Trans AM series racing.
Either way, my point was it is hard to believe GM will produce only a base Corvette with 450 to 470hp when they have a couple of over 500hp Camaros selling at the same time.
hig4s is offline
Old 12-21-2012, 10:16 PM
  #33
S'vette
S'vette's Avatar
Originally Posted by RJRSW
I have been driving vettes since I was 17 and by far the lions share of vette owners I have known over the years didn't have a clue or most could care less how many HP their car had.
Unless you are buying the car for the track what practical difference would 450 HP or 500 HP make to the average vette owner that only drives it on the street.
If this was true then why would people like me mod the car to make it faster when all we do is drive it on the street? Cuz it makes a difference thats why.
S'vette is offline
Old 12-21-2012, 10:20 PM
  #34
briannutter1
briannutter1's Avatar
But this is madness. How can GM expect the 2014 Corvette to sell with a measly 450hp when you can get a Camaro for probably thousands less with over 500hp? They're undercutting their own product.
Gen4 camaro SS got the original Lt4 just before the Ls switch. Chevy runs deep between the engineers at least.
briannutter1 is offline
Old 12-21-2012, 10:40 PM
  #35
hig4s
hig4s's Avatar
I actually believe the base Corvette will start a couple thousand less than the $54k the Camaro ZL1 starts at. If they did do a 427 for the Camaro, they would probably de-tune it about 40hp or more like they did in the ZL1, so say 460 hp for about $46k. As long as the base Corvette had say 470hp, that would work marketing wise.
hig4s is offline
Old 12-21-2012, 10:54 PM
  #36
McGirk94LT1
Not "production car" wise. 97 SS's were lt1's. 97 slp prepared SS and WS6 were lt4's. From what I understand, they are considerably rare, along the lines of 200 or so between firebird/camaro.
Old 12-22-2012, 12:51 AM
  #37
S'vette
S'vette's Avatar
So how much do we think the LT1 big brother (FI) will cost?
S'vette is offline
To 2014 LS7 engine option
Old 12-22-2012, 03:03 AM
  #38
Jinx
Jinx's Avatar
The ZL1 is not detuned, it's actually tuned up from the Cadillac original. Remember, it's the LSA, not the LS9.
They're not going to detune the LS7. Why would they?
.Jinx
Jinx is offline
Old 12-22-2012, 11:11 AM
  #39
formulaWA
formulaWA's Avatar
Default Gen 4 & gen 5
So does this mean that the Gen 4 engines will still continue to be in production along side the Gen 5 small block. Does anyone know what applications the Gen 5 will be used in besides the Corvette or is it intended to be exclusive to the Corvette for a while?
formulaWA is offline
Old 12-22-2012, 11:50 AM
  #40
timmyZ06
timmyZ06's Avatar
so we'll see camaro start dropping valves!!!
... just kidding
im not looking to start a **** storm, i tried to retain myself unsucessfully!!
timmyZ06 is offline
Quick Reply: 2014 LS7 engine option
