F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
Corvette C6 to 68 Camaro Conversion?
Old 02-24-2011, 10:14 AM
ronniej
ronniej's Avatar
St. Jude Donor '06
Default Corvette C6 to 68 Camaro Conversion?
I bought a 2007 C6 last night as a donor car. I'm probably crazy cause the car is pristine with only 8k miles and a 3LT car, but I want to convert it to a Gen 1 Camaro. I currently have a 68 Camaro that I'm doing a frame off resto on and would love to put the body on the vette roller. Has anyone ever seen or heard of this being done before? No need for any negative comments either...
ronniej is offline
Old 02-24-2011, 06:05 PM
Rickman
Rickman's Avatar
Ron,
I have never heard of anyone ever doing this before, but I am willing to watch and learn.
Rickman
Rickman is offline
Old 02-25-2011, 04:30 PM
Texas Stinger
Texas Stinger's Avatar
I'll buy what's left, how about a C6 on a C4 chassis.
Texas Stinger is offline
Old 02-25-2011, 06:46 PM
slo_z28
slo_z28's Avatar
Rodger @ Ironworks in bakersfield CA is doing this.
http://www.lateral-g.net/forums/showthread.php4?t=21450
It will take a LOT of time and Skill or a Ton of money to complete something like this.
slo_z28 is offline
Old 02-25-2011, 07:47 PM
ronniej
ronniej's Avatar
St. Jude Donor '06
Thanks for the link as I saved it. I would want to use my current C6 frame/rolling chassis and fit the camaro shell to it. Regardless, the LS2 will be fitted in the camaro.
ronniej is offline
Old 02-25-2011, 08:26 PM
slo_z28
slo_z28's Avatar
The wheelbase is significantly different, its not a bolt in thing. That said you could use the LS2 with a Detroit Speed and Engineering front subframe and Scotts Hot Rods in Oxnard CA has a IRS kit that can be adapted to your IRS rear if you're interested.
slo_z28 is offline
Old 02-25-2011, 10:09 PM
ronniej
ronniej's Avatar
St. Jude Donor '06
I planned on taking all the measurements this evening but ran out of time. Your last bit of info is exactly what I'm looking for.
ronniej is offline
Old 03-22-2011, 07:20 PM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
FYI.................
http://cgi.ebay.com/ebaymotors/1968-...c3f1253c#v4-44
Allthrottleandsomebottle is offline
Old 03-24-2011, 11:00 PM
ronniej
ronniej's Avatar
St. Jude Donor '06
OMG, that's exactly what I want to do! I'm gonna try and get in touch with them for more build pics. Thanks for the link.
Originally Posted by ALLTHROTTLE&NOBOTTLE
ronniej is offline
Old 01-19-2016, 10:47 AM
Willia
5th Gear
Willia's Avatar
Default 68 camaro c6 running gear
I'm on the last leg of this conversion. Built a frame to accept the c6 suspension sub frames. Moved the engine/transaxle/rear suspension, 2.375 " to the back to make up for the wheelbase difference. Actually, you end up with a front mid engine chassis, since the front of the motor is behind the front spindle line. Moved the firewall back 8" along with the dash. Back seat area was lost to the transaxle and since I'm running dual mode C6 exhaust which takes up the space formerly for the gas tank, I fabricated an aluminum saddle tank running the C6 dual fuel pumps located over the tranny. There is also a variance of track between the two cars, I've flared the front and rear fender arches. For those of you worried about a gas tank in the passenger compartment, a close container vented to the bottom outside was created to contain the tank. Just in case there are any Camaro purists out there, my starter was 68 RS 6 cylinder,powerglide car. Waste not want not.
Willia is offline
Old 10-24-2020, 11:53 AM
Willia
5th Gear
Willia's Avatar
Default project
Now on the final leg of the project, body is painted GM Competition Yellow, sits on Continental Extreme Contact tires. Computer problems mostly sorted out. Being greatly challenged by glass. Runs great.
Starting final assembly
Willia is offline
Old 10-27-2020, 07:56 AM
Chevy Guy
Chevy Guy's Avatar
There is someone on this forum putting a 69 camaro on a C5 chassis also, very clean work. I highly suggest you find and read that thread.
Chevy Guy is offline
To Corvette C6 to 68 Camaro Conversion?
Quick Reply: Corvette C6 to 68 Camaro Conversion?
