Corvette Forum
Go Back   Corvette Forum > Off Topic > F-Body General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2009, 09:24 PM   #1
CorvetteMike2004
CF Senior Member
Support Corvetteforum!
CorvetteMike2004's Avatar
Default I want to put a 700 tranny behind my 396? Will it work?
I have a 69 el camino with a 396 matched to an M-22 (yes a real M22) with a 12 bolt posi. My M-22 takes the large driveshaft yoke. I want to put a 700r4 in place of the M22. Im tired of shifting. Anyone know what I will have to change on the driveshaft to make this work? I want an overdrive tranny because I have 4:11 gears. Thanks for your input.
I have also thought about putting an LS1 in it. Opionons on that?
Corvette Mike
Heres a pic of my camino
CorvetteMike2004 is offline   Reply With Quote
Old 03-21-2010, 10:18 PM   #2
Chevy Guy
CF Senior Member
Chevy Guy's Avatar
Send a message via AIM to Chevy Guy
It can work if you want to spend the $$. A stock 700r4 wont last long if you drive aggressively.
Chevy Guy is online now   Reply With Quote
Old 03-22-2010, 11:25 AM   #3
superstreet
CF Senior Member
St. Jude Donor '10
superstreet's Avatar
Quote:
On both counts.
I have a 700 R-4 in my '69 that is from my '91 Z-28 and rebuilt it to handle about 500 hp. I use it with a lock-up converter. I have a kit on it that will lock-up the converter above 40 mph,but if I don't want it to lock-up I have a switch under the dash that will over-ride it and I can make it lock-up any time I want.
If you do get one,I recommend to get an 1987 or later 700 R-4. 86' and older 700's have a reputation for problems. If you stick with 87' and newer the trans will have a 30 spline input shaft and a 27 spline output shaft. A turbo 350 uses the same yoke as a 700.
superstreet is offline   Reply With Quote
Old 03-22-2010, 08:00 PM   #4
leadfoot4
CF Senior Member
leadfoot4's Avatar
I'm not positive about this, but aren't the 200-4Rs that were used on the Turbo Buicks able to be built up to actually be stronger that the 700R4? (not on the cheap, of course...)
leadfoot4 is offline   Reply With Quote
Old 03-22-2010, 09:15 PM   #5
angel71rs
CF Senior Member
200-4rs can be built to take a lot of hp. Have added advantage of 2.74 1st gear vs the 3.08 of the TH700.
If you have a 2.73 gear in the diff, the 3.08 is great for acceleration. But if you have deeper gears, 3.08 makes 1st gear a pain on street tires, especially around corners. You give it too much gas, rear end tries to come around. Not enough, 2nd kicks in too soon, blah acceleration due to monstrous gear spread between 1st and 2nd gear.
Lots of info on the 200-4r available on the net, like here:
http://www.drwtransmission.com/thm_200-4r.htm
angel71rs is offline   Reply With Quote
Reload this Page I want to put a 700 tranny behind my 396? Will it work?
Tags
396, tranny
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
