2010 Chevy Camaro Gets Mysterious Brake Weights
By Ben Wojdyla, 12:30 PM on Wed Apr 22 2009, 34,383 views (Edit, to draft, Slurp)
Copy this whole post to another site
Slurp cancel
sending request
Forumites at Camaro5 have been collectively scratching their heads for a couple days, wondering why there appear to be two layers of lead wheel weights stuck onto their brake calipers. It's a mystery Charlie Brown!
The confusion started when a poster uploaded an image of his new Camaro's Brembo calipers, on which were riding two rows of lead weights, normally affixed to the inside of a wheel rim to balance the tire. This led everyone with a Camaro to run outside to see it their mullet machine's also had the weights, which they do, at least on among the folks on the forum. GM has not answered to the confusion yet, but the leading theory is they were place on the caliper as a quick and dirty fix to alleviate brake squeal. From a physics perspective, this explanation is plausible, as resonant frequency is in large part determined by mass, and by changing the vibrating mass of the caliper with the weights, a troublesome squeal would be eliminated for a particular driving condition.
The trouble is if they're using normal brake weights, the heat cycling of the caliper will eventually cause the adhesive to fail and, if things get too serious on the track, the lead could actually melt. Though it's an odd issue and not really a big deal, we'll be keeping you in on the loop during Camaro brake-gate, though we recommend Camaro owners visit their local dealer and have their muffler bearings, blinker fluid, and piston-return springs checked out, just in case. Click here for the high-resolution image. Thanks for the tip Ethan!
__________________ Polo Green 95 LT1 6-spd 383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske-Hardbar dual rate coilovers/Wilwood 6pot brakes NCCC Governor/Membership/WebMaster:www.baystatecorvetteclub.com
