F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
steering wheel shimmy
Old 01-09-2008, 09:42 PM
footba4672
footba4672's Avatar
Default steering wheel shimmy
I have a 2002 Trans -Am WS6 with 20" wheels. The wheels are perfectly balanced and yet I have a steering wheel shimmy only between 55-65 MPH. Does anyone have any idea what maybe causing this and possibly know of a fix......
footba4672 is offline
Old 01-10-2008, 05:59 AM
mph1972
Support Corvetteforum!
mph1972's Avatar
Cruise-In VIII Veteran
St. Jude Donor '07
When does it do it? during braking or while driving normally? First thing that comes to mind is balancing, but you claim they are balanced, so maybe one of the tires pressure is off a bit. If you have low pressure in one of your (typically fronts) tires it could cause this. Just a thought.
mph1972 is offline
Old 01-14-2008, 07:57 PM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
These cars don't normally shimmy...It is my guess that it is the 20in wheel..I'd almost guarentee it!
do you still have the stockers? A set of 17X9.5 and 17X11 in the rear are best... These cars do not act very nicely with 20in. wheels..
Just my opinion. I have owned 3 different 4th gen cars. typically a front end alignment, wheel/tire balancing is ALL that is needed.
TXGS507 is offline
Old 01-15-2008, 09:58 AM
LordVader
LordVader's Avatar
LordVader is offline
Old 01-17-2008, 08:57 PM
cerino2000
cerino2000's Avatar
How many miles are on the tires?
cerino2000 is offline
Old 01-19-2008, 10:02 AM
VetteMark
VetteMark's Avatar
You should have them 'Road Force Balanced' to insure that the tire force is within spec all the way around. Tires with uneven forces are more common than you think and have been the root of a few of my steering wheel shimmy.
VetteMark is offline
Old 01-19-2008, 04:40 PM
redrose
redrose's Avatar
check for a ''loose'' tie rod end...but likely you've entered the realm of tire engineering with the 20's...maybe additional ''caster'' will help, maybe higher OR lower tire pressure in the fronts OR the rears (try rears 2-4 lbs more than fronts to start)
redrose is offline
Old 01-20-2008, 07:55 PM
bsim
bsim's Avatar
A flat spot would do this too...
bsim is offline
Old 01-24-2008, 02:44 PM
ruf455
ruf455's Avatar
ruf455 is offline
To steering wheel shimmy
Quick Reply: steering wheel shimmy
