Corvette Forum
Go Back   Corvette Forum > Off Topic > F-Body General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
F-Body General Discussion Non-Corvette General Discussion on Camaro, Firebird and Trans Am, F-Body Technical Info, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-18-2007, 02:57 AM   #1
Procrastination Racing
CF Senior Member
Procrastination Racing's Avatar
Default Rear end roar in 2000 Camaro
I checked out a Camaro today and it seemed to have a bit of roar in the rear of the body on the highway. I haven't noticed that in others but haven't been on the same section of road. I wasn't sure, but I think it was still there at lower speeds on the surface streets.
The car has 86,000 on it and is the V6, if that makes a difference.
Another I looked had seemed to have a bit of shimmy when taking off and running about 10-20 mph. How complicated is the front end alignment? Is it a standard alignment or is there a bunch of things Chevy requires that makes this one more work and more costly?
Procrastination Racing is offline   Reply With Quote
Old 10-18-2007, 03:42 PM   #2
Mojave
CF Senior Member
Mojave's Avatar
A roaring noise from the rear end is probably a bearing in the rear end, and most of the time, it is the pinon bearing. 10 bolt axles are notorious for starving the pinon bearing of oil, which causes it to wear and start making noise. Budget about $600 or so to have the rear end professional rebuilt (replace bearings and seals).
The alignment on a 4th gen is pretty simple. There are slotted mounting holes to allow the adjustment of camber and caster (and of course toe is adjustable). A bad alignment, however, wouldn't cause a shimmy unless it was really, really, really off.
Mojave is offline   Reply With Quote
Old 10-19-2007, 03:20 PM   #3
CF Senior Member
Thanks, it is good to know. My '89 GMC has the wonderful GM corporate thinking of "let's save money by not making it adjustable" front end. As such, an alignment means the front has to be cut apart and an adjustable alignment kit installed.
I was afraid that by the time they got to '97 with Camaros, they had invented even more money saving ideas.
Old 10-24-2007, 12:45 PM   #4
Buceman
Junior Member
I have a 2000 Camaro and my bearing froze in the rearend. I had to get a new housing and while at it put an Auburn diff and 3:42's in
Runs like a champ now.
If your in the market for an F-Body I can give you in fo on mine
Buce
Buceman is offline   Reply With Quote
Old 11-06-2007, 09:57 PM   #5
Nzzz
CF Senior Member
Nzzz's Avatar
Id get it serviced soon.
Nzzz is offline   Reply With Quote
Old 11-14-2007, 05:27 PM   #6
TomcatMF
Junior Member
My '97 SS did the same thing. The pinion seal was leaking and that cause the bearing to seize and spin. It was a very expensive repair.
TomcatMF is offline   Reply With Quote
Old 11-14-2007, 09:43 PM   #7
0EPP
CF Senior Member
I sell a lot of Moser 12 bolt and 9 inch rearends for these cars. The Moser 9 inch is my most popular seller, and is designed to be a direct bolt in.
Here is a link to the Moser 9 inch. Bob
http://www.exoticperformanceplus.com....html?item=145
EPP is offline   Reply With Quote
Reload this Page Rear end roar in 2000 Camaro
Tags
2000, 2001, alignment, bodies, camaro, corvette, end, noise, rear, roaring, roring, ss, z28
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
