Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2003, 07:50 AM   #1
foundvettelifeisgood
CF Senior Member
Default Need fuel line help--AN and braided hose
Can anyone walk me through what to buy? I'm looking for specifics on AN fittings and hose from the stock pump to a new cartridge replaceable filter (advise?) to a Holley 670 Street Avenger.
Also, when I take off the old flare fitting from the pump, how do I keep the gas from flowing while I work?
Thanks. :cheers:
foundvettelifeisgood is offline   Reply With Quote
Old 11-21-2003, 09:29 AM   #2
GregP
CF Senior Member
GregP's Avatar
Default Re: Need fuel line help--AN and braided hose (foundvettelifeisgood)
Check on http://www.jegs.com, you can find all the fittings there. For moderate HP you can run all AN6 stuff, equivalent to a 3/8" line (I think the stock hard lines are usually 5/16 ??). You will need:
Fuel pumps usually have NPT threads after you remove the brass inverted flair fitting, so you would use an NPT to AN straight fitting for fuel pump. Fuel pump is probably 1/4 NPT but some high performance pumps are 3/8 NPT.
If 1/4 NPT then get a 1/4NPT-AN6 #023-FCM2004
You can also go direct from the old inverted flair to AN using something like #799-640380 or 799-64-330. You need to check your fuel pump to make sure which way to go.
(deleted old line)
For an inline filter you can use something like the Russel unit #799-650130
You can use braded hose, but personally I prefer the push-lock blue hose as braided hose will cut through anything it's near unless you secure it carefully several places along it's length. Since you asked on braided hose I'll list the braided hose stuff. You will usually work best with a 90* hose end at the pump and "straight" at your carb fuel line adapter so....
Hose Ends:
(1 X) 023-FCM4032
(3 X) 023-FCM1012 (to splice in the fuel filter mid-stream)
and hose:
023-FCA0603
-Greg
Just looked up your Street Avenger carb. You will need a dual feed to AN adapter instead of just the single inlet fitting. (Also, changed to 1 90* and 3 straight hose fittings).
Look at #799-641090K or #555-15205. Either will also need a 023-FCM2005 3/8NPT-AN6 straight adapter.
(with the #555-15205 you will also need a 799-662030 plug it you don't use a fuel pressure gauge)
-Greg
[Modified by GregP, 8:31 AM 11/21/2003]
[Modified by GregP, 8:39 AM 11/21/2003]
[Modified by GregP, 8:40 AM 11/21/2003]
[Modified by GregP, 8:42 AM 11/21/2003]
GregP is offline   Reply With Quote
Old 11-25-2003, 07:20 PM   #3
Scooter70
CF Senior Member
Scooter70's Avatar
Send a message via AIM to Scooter70
Summit sells (almost) everything in one package. You tell them which carb you have and they'll send the line and the correct fittings. See p. 45 of the latest catalog (with Santa and the blown Rustang on the cover) The fuel filter and associated fitting would have to be ordered separate.
Scooter70 is offline   Reply With Quote
Old 11-25-2003, 07:51 PM   #4
CF Senior Member
Default Re: Need fuel line help--AN and braided hose (GregP)
Thanks, that's just the kind of effort I was hoping for.
I pulled the NPT off of the fuel pump using a 5/8" flare nut wrench, so I believe it's 3/8" NPT like the fuel line fittings at the 4011 carb I'm pulling.
The old metal fuel line is bent in the correct path, and it would seem that a 45 degree hose end fitting would trace it better than a 90 degree at the pump. However, when you look at the pre-made stuff at Summit or Jegs, it's always a 90. :crazy:
Thanks a lot for all the help.
Reload this Page Need fuel line help--AN and braided hose
Tags
an6, braided, fuel, lines, support
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel Line & Fittings Question Ramanstud C4 Tech/Performance 11 04-24-2003 12:28 AM
fuel pressure help CDaniel525 Engine Mods 12 07-12-2002 08:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
