Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2003, 08:12 AM   #1
EDDIEJ82
CF Senior Member
EDDIEJ82's Avatar
Default Help!!! Will 2.08 valves be too much for my 383
OK guys, I'm building a 383 and have a offy divided phlemun 360 turbo thrust tunnel ram w/ 2- 600 edelbrock's on top.
I'm ready to select my heads. I found a set of irons w/ 64cc, 200cc runners and 2.08 int 1.60 ext
Will the 2.08's be too much for the 200cc runners and will the larger displacement of the 383 cover up the bog of the larger valve.
This will be the first time I have set up a tunnel ram motor and I know it has diffrent breathing characteristics, but just how much? will the 2.08's help or hurt (smaller valve more velocity, bigger valve more volume) ?
It probably wouldn't matter but this is a dual purpose car that I drive on the street.
Also I haven't cut the block yet, do you think a 415 might be better with this setup?
Thanks for your input
Eddie
EDDIEJ82 is offline   Reply With Quote
Old 11-20-2003, 12:27 PM   #2
gkull
CF Senior Member
gkull's Avatar
Default Re: Help!!! Will 2.08 valves be too much for my 383 (EDDIEJ82)
The 415ci will always make better use of a tunnel ram.
IMO - The heads are only a small part of the total equation. You cam and total intake plenum volume have allot to do with it.
If you want to look at it another way. Compare the valve size and runner cc of a big block Chevy to a small block. 2.18 or 2.25 intakes and the ci puts a 415 right in with the big block 396/402's and the mighty 427's
Our small block heads don't even approach the CFM levels of big blocks unless you get into real race heads
gkull is offline   Reply With Quote
Reload this Page Help!!! Will 2.08 valves be too much for my 383
Tags
208, 383, valve, valves
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Is an aluminum frame safe for the track?? mattsmallett C6 Z06 Discussion 34 07-08-2005 05:31 PM
SAE papers and other stuff (Very long) Runge_Kutta C6 Z06 Discussion 18 05-08-2005 03:29 PM
I WON!!"Fastest Street Vette in Tx" 427Hotrod C1 & C2 Corvettes 29 12-21-2003 10:20 PM
AutoCross - What Air Pressure for Non-Runflats? RacerChris C5 Tech 9 07-07-2003 03:14 PM
Any thoughts on my next cam? Phil97SVT C5 Tech 10 10-30-2002 10:14 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
