Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2003, 12:28 AM   #1
GRX
CF Senior Member
GRX's Avatar
Default Finally! Started but headers glow red!
I posted this http://forums.corvetteforum.com/zerothread?id=693308 in C4
Tech ...maybe you guys here in Engine mods can offer an opinion why this is happening after motor warms up at about 1500RPM.
Cam:Intake: Duration: 260*
Exhaust: Duration: 270*
Specs at .050" tappet lift:
Intake: Duration: 209*
Exhaust: Duration: 217*
Intake:
Opens at: -5.5 ATDC
Closes at: 34.5 ABDC
Exhaust:
Opens at: 46.5 BBDC
Closes at: -9.5 BTDC
Lobe Lift:
Intake: .330" x 1.5 rocker= .495"
Exhaust: .343" x 1.5 rocker= .515"
Lobe separation: 114
Heads are AFR 190's large valves
Stock intake.
CR is about 8.7:1
Thank you.
[Modified by GRX, 8:34 PM 11/17/2003]
GRX is offline   Reply With Quote
Old 11-18-2003, 02:31 AM   #2
SWCDuke
CF Senior Member
Default Re: Finally! Started but headers glow red! (GRX)
What does your ignition map look like?
Duke
SWCDuke is offline   Reply With Quote
Old 11-18-2003, 02:43 AM   #3
GRX
CF Senior Member
GRX's Avatar
Default Re: Finally! Started but headers glow red! (SWCDuke)
Well I have the stock prom in it right now.
Old 11-18-2003, 04:56 AM   #4
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
Check your distributor you could be off a tooth, thats what casued mine to glow!
LD85 is offline   Reply With Quote
Old 11-18-2003, 01:35 PM   #5
88-406
CF Senior Member
St. Jude Donor '05
88-406's Avatar
Send a message via AIM to 88-406 Send a message via Yahoo to 88-406
Verify your fuel pressure is what it supposed to be. Also make sure your base timming is 6-10 with the wire (EST?) disconected. How did the engine sound? Did it rev smoothly or rough? Also is this with stock chip and stock injectors?
KM
[Modified by 88-406, 9:36 AM 11/18/2003]
[Modified by 88-406, 9:37 AM 11/18/2003]
88-406 is offline   Reply With Quote
Old 11-18-2003, 01:42 PM   #6
GRX
CF Senior Member
GRX's Avatar
Default Re: Finally! Started but headers glow red! (88-406)
Fuel press is around 40psi. Timing was set to just start the motor. Engine was smooth. Yes, stock chip and injectors.
Old 11-18-2003, 01:49 PM   #7
black bart
CF Senior Member
black bart's Avatar
In addition to slow timming a vaccum leak can cause that also.
black bart is offline   Reply With Quote
Old 11-18-2003, 01:52 PM   #8
88-406
CF Senior Member
St. Jude Donor '05
88-406's Avatar
VERIFY your timming with a light. A few degrees in the wrong direction and you get what you got! How confident are you that your pointer is setup correctly? You wouldn't want to hurt that beautiful Bowtie would you?
I would think your engine should give a decent idle with the stock Inj's and chip. The only reason I say this is because I've started my 383 with my stock chip before and it idled fine.
KM
Reload this Page Finally! Started but headers glow red!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Finally! Got her started...but... GRX C4 Tech/Performance 10 11-18-2003 12:12 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
