Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-17-2003, 10:47 PM   #1
TrueBlue ChevyDude
CF Senior Member
TrueBlue ChevyDude's Avatar
Location: Brandywine, Chester and Ridley Valleys Pennsylvania
Default Talking clutch fork angle blues (Mcleod Street Twin)
The last couple times I had the engine/trans apart, I've experimented with the clutch fork angle as it comes out of the bellhousing.
When I got the Street Twin 4 years ago or so, I had some clutch release issues as a result of the clutch fork angle being towards the trans and thus not having enough mechanical leverage to properly actuate the clutch. Ever since, I've been playing with the clutch fork angle using an adjustable ball stud and the Mcleod adjustable throwout bearing.
This time around I have the fork angle further towards the engine (for better mechanical leverage) than ever before. The pedal feels good when cycling it up and down, not too stiff, not too buttery.
My question is this: Is it possible to adjust the fork angle so far towards the engine during install that you run a risk of hitting the front cover of the trans with the clutch fork when at full release after everything is assembled? :chevy
TrueBlue ChevyDude is offline   Reply With Quote
Old 11-18-2003, 09:09 AM   #2
427Hotrod
CF Senior Member
427Hotrod's Avatar
Default Re: Talking clutch fork angle blues (TrueBlue ChevyDude)
On mine, when I went to far forward with arm (too long of stud) the arm hit the fingers of the pressure plate first. Made a heck of a racket as one of them just barely dinged the arm during rotation.
JIM
427Hotrod is offline   Reply With Quote
Old 11-18-2003, 12:18 PM   #3
632C2
CF Senior Member
I don't think that hitting the front cover of the trans will be an issue. There is a shoulder on the trans bearing retainer that limits the T/O bearing travel. Even if it did hit, nothing is moving there anyway.
When I was setting up my Street Twin, I ran into a similar issue that Jim had. My T/O fork was hitting the bolt heads on the pressure plate. A little ball stud adjustment took care of that.
Steve
632C2 is offline   Reply With Quote
Old 11-18-2003, 01:44 PM   #4
TrueBlue ChevyDude
CF Senior Member
Default Re: Talking clutch fork angle blues (542C2)
Laying on your back for two hours with a 6 pack of Yuengling Lager within arms reach might have a little to do with my misstep.
All these pivot points and angles, obviously I am confused. Not to mention being dizzy after getting up off the garage floor :lol:
427 Hotrod and 542C2- was the rotating noise you guys experienced happening with the clutch released or engaged?
I'm afraid of my problems happening when the clutch is released, given the extra length I added to the ball stud.
:cheers:
Old 11-18-2003, 05:03 PM   #5
632C2
CF Senior Member
The noise occurred when the clutch was released. You can hear it and feel it by just cranking on the starter.
Old 11-18-2003, 08:38 PM   #6
427Hotrod
CF Senior Member
427Hotrod's Avatar
Dang Steve....you must have had the same problem I did! At first I thought starter needed to be shimmed (even though I've never had to do it on one of my cars before) for the new flywheel. Sounded just like a binding starter/flywheel as it turned. Eventually I found arm just barely dinging the finger height adjusting nut. You reminded me..it was the nut...not the finger.
JIM
Old 11-19-2003, 12:01 PM   #7
TrueBlue ChevyDude
CF Senior Member
Default Re: Talking clutch fork angle blues (427Hotrod)
Thanks very much for the replies guys, I checked out the clearance between the fork and spring adjustment nuts just having someone rotate the engine from the balancer. It seems oh so close, just barely am I getting a hairline scrape using prussian blue on all of the adjustment nuts. At least I guess this means that everything is shimmed right and my engine/trans are straight:lol:
I am going to do a little "improvised machining" in the garage here with a grinding wheel, and dimple the fork in the area that the spring adjustment nut might possibly touch. This way I can go a little further with the adj. ball stud this time and not get nervous. :chevy
Reload this Page Talking clutch fork angle blues (Mcleod Street Twin)
Tags
angle, chevy, clutch, fork, mcleod, street, twin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
