Quote:
I was thinking these rods with a scat 9000 crank.
Not exactly sure why you'd think that is a "bad idea."?
I am using a SCAT 9000 crank with SCAT H-beam rods.
A cast (steel, nodular) crank can be safely used upwards of 600hp without much issue. A 450hp motor does NOT need a 800-1100 dollar crank, the money would be WELL spent elsewhere. RPM is the main issue, if you want to run above 6500rpm, YES a forged crank would be a "good" idea. It can resist the harmonics a lot better than a casting.
:cheers:
