Has anyone heard or used a brand of timing chains called CAM CORRECT? It goes for $530 at :www.competitionproducts.com They claim to have variable valve timing (the cam is advanced through the lower RPM range, and then it's retarded (in crankshaft degrees I mean) throughout the higher RPM's. They have a site but it doesn't have much info: http://www.camcorrect.com
In all these years I've been reading magazines and forum posts, I've never came across them.
Any feedback is highly appreciated.
Re: Variable Valve Timing on a Chevy V8? (El Mago)
this one is enw to me, there''s another one called hotrockers, their setup has a variable fulcrum on the rocker and it uses external electrical motors to change the ratio.
I run one of those in 69 in my 428 Cobra. It was a gear that went of the cam and used a normal timing chain. What is was is a gear that was spring loaded. At low speeds the spring was not strong enough to hold the cam and it advanced. As rpm built the load on the spring decreased and the cam sprocket retarted. It was call a Vari Cam. It never really made much difference.
While I never saw what you are talking about for $530 I could be wrong but that is what I ran in 69.
