Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2003, 10:59 PM   #1
dsagers
CF Senior Member
dsagers's Avatar
Default OT: Help me find a bolt or cap head screw. 7.5" long, 7/16 -20 fine thread
Need the bolt that goes into the center of the front of the crank. Added a pulley for a street blower and a mandrel for the dry sump, and now the bolt isn't long enough.
I need one 7.5" long, 7/16 -20 fine thread, grade 8.
Have checked the local hardware stores and several fastener supply shops.
Anyone know where to find something like this? One guy suggested a threaded rod, and cut to length. Problem is that the old bolt is a grade 8, and I can find a threaded rod that is anywhere as strong .
dsagers is offline   Reply With Quote
Old 11-03-2003, 12:11 AM   #2
redvetracr
CF Senior Member
redvetracr's Avatar
Default Re: OT: Help me find a bolt or cap head screw. 7.5" long, 7/16 -20 fine thread (dsagers)
I have (almost) the same bolt in my crank holding the dry sump drive. "John Deere"!! They have a fastner book and can get almost anything. CHEAP TOO.
...redvetracr
redvetracr is offline   Reply With Quote
Old 11-03-2003, 01:59 AM   #3
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
You must have a Callies crank. Try a truck spring center bolt. That's what I used to make my damper pulling tool. They have a round head, but if you can't get a grip, you could weld a nut to it for a wrench. Good luck, and...
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 11-03-2003, 07:25 AM   #4
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
AH yes needing the specal bolt.
Here is a link to one, You can just cut it to length, 7 1/2" in that size grade 8 is tough to find.
If you search on-line you can finsd some more companies too!
Look under cap screws and go from there
http://www.mcmaster.com/
Cap Screws
This item matches all of your specifications.
Part Number 91257A487 $4.40 per Pack of 1
Material
Alloy Steel
Material Type
Grade 8 Zinc and Yellow Chromate-Plated Alloy Steel
Head Style
Standard Hex
System of Measurement
Inch
Thread Size
7/16"-20
Length
8"
Thread Style
Standard Right Handed
Thread Length
Partially Threaded
Specifications Met
SAE J429
:cheers:
Allthrottleandsomebottle is online now   Reply With Quote
Old 11-03-2003, 12:37 PM   #5
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
That one above sounds like it will do the trick. If for some reason, it won't, let me know. and I'll give you the number for Callies. Even if your crank isn't Callies, they use a deeply recessed thread and a long bolt, too. When I talked to them, I got the impression they could supply long bolts. I called to ask about a bolt for mine, which needs to be the minimal length (nothing on the front of the crank, but the damper) and they told me it takes a 3.5" bolt, and acted like I should be able to find it anywhere. I haven't spent alot of time looking for one, yet, but I haven't "tripped" over one either. How long is your old bolt? Are you willing to part with it? Let me know if you want that phone number. Good luck, and...
RACE ON!!!
Old 11-04-2003, 12:01 AM   #6
dsagers
CF Senior Member
dsagers's Avatar
Default Re: OT: Help me find a bolt or cap head screw. 7.5" long, 7/16 -20 fine thread (redvetracr)
Redvetracr: Great info, a John Deere specially modified Corvette! Wonder how that would stack up against the Callaway?
Have a John Deere dealer just a few minutes from the office so it'll be an easy stop during lunch.
CFI-EFI: If you are in the Salt Lake City area, IM me and you can have the bolt I was using. It is a gold color grade 8, six inches long, not including the head.
Allthrottle and Nobottle: Thanks for the link to the McMaster catalog, found some interesting items there.
Old 11-04-2003, 09:06 AM   #7
redvetracr
CF Senior Member
redvetracr's Avatar
dsagers,
you (of course) have heard the phrase "NOTHING RUNS LIKE A DEERE" haven`t you?? ...redvetracr
Old 11-04-2003, 12:00 PM   #8
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Quote:
Redvetracr: Great info, a John Deere specially modified Corvette! Wonder how that would stack up against the Callaway?.
My questions is, if you run a John Deere decal, will they pay contingency money?
Damn, wrong color. Seriously, I need a 3.5" bolt. I would make it my business to be in the Salt Lake area, if I could use it. That is a great offer, and I really appreciate it. Thanks, and...
RACE ON!!!
Reload this Page OT: Help me find a bolt or cap head screw. 7.5" long, 7/16 -20 fine thread
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
