Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-27-2003, 11:36 PM   #1
NASCAR314
CF Senior Member
NASCAR314's Avatar
Default Cooler weather and an un-heated intake manifold question for carb. motors
Question for any engine builders of carburated big-blocks:
If your running a non-heated tunnel ram intake manifold with no choke, aside from starting considerations, at what temperature (intake air temp.) do you risk washing the cylinder walls with raw gasoline that was not atomized in the intake charge due to icing from the "venturi effect" of the carbs?
I don't want to damage the engine by wearing the cylinder walls prematurely.
Or, is this even a problem to worry about?
Motor in question is a 454, low compression, with tunnel ram and two Carter AFB's. Temperature in question would be the 30deg. to 50deg. range.
Intake has no heat riser or hot air intake system.
Thanks,
NASCAR314 is offline   Reply With Quote
Reload this Page Cooler weather and an un-heated intake manifold question for carb. motors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
