Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-26-2003, 09:59 AM   #1
MOTORCITY
CF Member
Default scat connecting rods
I am planning a rebuild on my 66 327/300hp and I want to use a better connecting rod. Scat seems to be the one of the only few that make an inexpensive connecting rod, for small journal cranks. Anyone had any opinions/experiance on how good thier rods are?
MOTORCITY is offline   Reply With Quote
Old 10-26-2003, 11:28 AM   #2
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Default Re: scat connecting rods (MOTORCITY)
*I* have only heard good things about them. Of course they're not Olivers or Carillos, but that's not what you seem to want. Good luck, and...
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 10-26-2003, 01:57 PM   #3
VETDRMS
CF Senior Member
VETDRMS's Avatar
I have had good luck with mine thus far. I am running 6.0" H-Beams with 7/16 cap screws. I'm sure they will be fine, rev limit is 6700.
Only time will tell, but "I" have heard good things as well.
Good Luck!
:cheers:
VETDRMS is offline   Reply With Quote
Old 10-26-2003, 03:21 PM   #4
MOTORCITY
CF Member
Default Re: scat connecting rods (VETDRMS)
Thanks for the info. I don't want a rod to break and damage my numbers matching block.
Old 10-26-2003, 05:00 PM   #5
66427-450
CF Senior Member
66427-450's Avatar
Send a message via AIM to 66427-450
don't worry, those SCAT rods are significantly stronger than the rods that came in your engine from the factory.
:seeya
66427-450 is offline   Reply With Quote
Old 10-26-2003, 08:54 PM   #6
SWCDuke
CF Senior Member
You don't need a better rod for a 5500 RPM engine. Even if your engine has the early small bearing rods without the little hump of metal adjacent to the bolt seats, they are satisfactory as is.
If you want to be safe, you could buy a set of new OE type rods, which are the latest design. For engines that will see sustained revs over 6000 or peak revs up to 8000 the Crower Sportsman are the way to go.
Duke
SWCDuke is offline   Reply With Quote
Old 10-28-2003, 12:01 PM   #7
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
Default Re: scat connecting rods (SWCDuke)
Check these out also: http://www.catpep.com/Products/Produ..._Category_ID=6
These are the ones I went with :)
SmokedTires is offline   Reply With Quote
Old 11-06-2003, 08:57 PM   #8
No Go
CF Senior Member
I'm using SCAT 5.7 H-beam rods and I'm mightily impressed. The dowelled cap, ARP rod capscrew, and the floating pistons.
For the price they are better than having a set of OEM rebuilt if you include the time and what not.
They are cool looking too!
No Go is offline   Reply With Quote
Old 11-16-2003, 11:13 AM   #9
Lionsden
CF Senior Member
Lionsden's Avatar
Send a message via ICQ to Lionsden
My reasoning for going with Scat rods was economics. New rod bolts, magafluxing, and resizing the old rods wasn't much less than the Scat rods.
Engine is still on the engine stand so I can't comment on durability.
Lionsden is offline   Reply With Quote
Old 11-22-2003, 09:09 PM   #10
zrracer
CF Senior Member
St. Jude Donor '11
Where is a good place to buy SCAT stuff ?
Thks,
Robin
:cheers:
zrracer is offline   Reply With Quote
Reload this Page scat connecting rods
Tags
break, connecting, corvette, engine, rods, scat
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
5.7 or 6 inch connecting rods? hz900 C4 Tech/Performance 14 06-01-2005 10:56 AM
Connecting rod question Entropy C3 Tech/Performance 14 03-04-2005 07:13 PM
381 Stroker using the stock PM rods? 96GS#007 C4 Tech/Performance 9 10-04-2004 09:26 AM
What piston, connecting rods, crankshaft combo should i put in my 383 for most HP?? bluelotus0 C3 Tech/Performance 12 02-22-2004 03:52 AM
Scat H-Beam Connecting rods Guru_4_hire C3 Tech/Performance 13 12-15-2003 03:36 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
