Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-24-2003, 01:40 PM   #1
MrNuke
CF Senior Member
MrNuke's Avatar
Default How much power is needed to cut tires loose at 50+Mph?
As topic asks. I know a guy who has an 94 LT1 with 3.54's and mods, and his car breaks the tires lose at 50-55mph. Curious to know how much power you need for that. He claimshe has 400rwhp.
Is that true?
[Modified by MrNuke, 12:43 PM 10/24/2003]
MrNuke is offline   Reply With Quote
Old 10-24-2003, 08:13 PM   #2
Bearcat
CF Senior Member
Bearcat's Avatar
Default Re: How much power is needed to cut tires loose at 50+Mph? (MrNuke)
I don't know. But I am capable of that. I'm at 5800 feet altitude, and with my naturally aspirated 427 big block that I built up, I tested it and shifting from first to second at 7000 rpm, I lit up the tires from around 65 to about 85 before it stopped fishtailing. And I'm still trying to get the Gold Claw tuned properly.
It's a 3.36 rear end that I dislike. I really need more like a 3.70 to 3.90 to take advantage of the high rpm of this motor.
Just go big block, or big small block, and I'll bet you can.
Bearcat is offline   Reply With Quote
Old 10-24-2003, 10:25 PM   #3
632C2
CF Senior Member
Is he saying that he can break the tires loose while shifting gears or by merely nailing it while doing 50-55 and cruising on the freeway?
Steve
632C2 is offline   Reply With Quote
Old 10-24-2003, 11:58 PM   #4
BacaBill
CF Senior Member
BacaBill's Avatar
Default Re: How much power is needed to cut tires loose at 50+Mph? (542C2)
Won't a little torque convertor (like out of a Vega) do that in any V8?
I knew a guy I grew up near that had a Vega convertor in his Chevelle BB & it would smoke the tires even if he punched the gas at 60mph. I was only 12 or 13 at the time so I could be wrong.
Bill
BacaBill is offline   Reply With Quote
Old 10-25-2003, 11:36 AM   #5
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
Steve
:iagree: It's much easier to bark the tires shifting at 50 mph, or spinning the wheels so that the speedo reads 50+ mph than it is to actually break the tires loose rolling at 50+mph :yesnod: .
SmokedTires is offline   Reply With Quote
Old 10-25-2003, 06:20 PM   #6
MrNuke
CF Senior Member
MrNuke's Avatar
Default Re: How much power is needed to cut tires loose at 50+Mph? (SmokedTires)
It is automatic and they said , he can floor it at 50-55mph and when the car downshifts into 2nd (I guess) he loses traction. Not a chirp but starts spinning the tires.
Old 10-25-2003, 08:26 PM   #7
SleepieAce
CF Senior Member
SleepieAce's Avatar
Location: Kentucky basketball is life the rest is just details
Send a message via AIM to SleepieAce
I can do it in a C5 with the mods in my sig. I'm driving a M6, though, and I think that makes it easier. I haven't dynoed the car, but I know its way over 400 rwhp.
Edit: BTW, 50 mph is the bottom of second and it will spin the tires while rolling or while shifting up. Part of the problem is the stock runflats, which I plan on changing this spring. :cheers:
[Modified by SleepieAce, 7:29 PM 10/25/2003]
SleepieAce is offline   Reply With Quote
Old 10-25-2003, 08:53 PM   #8
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
I don't know but I can be driving along in 3rd gear and just roll on the throttle around 4000 and break the tires loose. No shifting involved, just rolling on the throttle. Don't know the speed but around the middle of 3rd gear. 4th is the 1st gear I don't have to worry about loosing it.
norvalwilhelm is offline   Reply With Quote
Old 10-25-2003, 11:42 PM   #9
MrNuke
CF Senior Member
MrNuke's Avatar
Default Re: How much power is needed to cut tires loose at 50+Mph? (norvalwilhelm)
And what mods / HP are you running?
Old 10-26-2003, 01:14 AM   #10
89gta383
CF Senior Member
I used to do it with my old 383, superram, 219, 3.73 gears, 3500 yank combo.
89gta383 is offline   Reply With Quote
Old 10-28-2003, 02:25 PM   #11
Chuck Harmon
CF Senior Member
Chuck Harmon's Avatar
My 2002 ZO6 can break the tires loose in 2nd below 60mph simply flooring it, no shift, if the pavement has the slightest bit of dust on it and the traction control is off. It makes 350 rwhp.
My L88 clone makes 480rwhp and it can break the tires loose in 3rd and sometimes 4th at 100+ mph if the pavement isn't perfect. I must be very careful when flooring the car in the first 3 gears (3rd is 102 @ 6500rpm) because I can get sideways in the blink of an eye. And I still have 3 gears left! :D If you listen to the recording I have for the '69 when you visit my website (click my sig and click the Blue Vette) you can hear me accelerating onto a highway. I was not revving at a stop. 1st gear is only smoke, 2nd is only smoke, 3rd gets a bite, but I had to feather the throttle because of traffic. An honest 500rwhp really is more than most people can imagine in a 3200 pound car.
Chuck
[Modified by Chuck Harmon, 10:31 AM 10/28/2003]
Chuck Harmon is offline   Reply With Quote
Old 10-28-2003, 10:23 PM   #12
632C2
CF Senior Member
Default Re: How much power is needed to cut tires loose at 50+Mph? (Chuck Harmon)
My '67 with 838 flywheel horsepower(722 ft/lbs torque) and 714 rear wheel horsepower(624 rear wheel torque) would destroy the tires in 1st, 2nd, and 3rd (I use a 5 speed G-Force trans with 5th gear being 1:1).
I only tried this at or below 40 - 50 mph because it was very hard to control and I can't stand the thought of destroying this car.
One time I did roll into the throttle while doing about 60-65mph in 5th gear(1:1)on the freeway. If my memory serves me correctly, this was around 3000-3500rpm. The car lurched to the left and flat took off. I did not notice any tire spin though my passenger was terrified. Looking at my DynoJet graphs, I am developing around 500 ft/lbs of torque at 3500rpm.
My 1990 Callaway Twin Turbo that makes 607 rear wheel horsepower and 735 rear wheel torque did not break the tires loose in 4th gear(1:1) when I nailed it and the boost came on. However, it did spin the Center Force Dual Friction clutch. With a better clutch it MIGHT have spun the tires.
Steve
Old 10-28-2003, 11:51 PM   #13
MrNuke
CF Senior Member
MrNuke's Avatar
Steve
Wow.. Thats some power..
SO I'm gathering around 400-450CHP is needed to spin them on an automatic at 50-55mph.
Also tire condition probably matters.. Old GSC = spinning, new non GSC mayeb not spin.
Old 10-29-2003, 10:51 AM   #14
MikeC
CF Senior Member
MikeC's Avatar
:yesnod: And it scared the crap outta me when she broke loose too! I can't imagine what the ride would be like at full throttle with you at the wheel!
He has this shiney thing sticking out of his hood. His HP level is between "a whole bunch" and "I think I need some clean underwear"
[Modified by MikeC, 9:51 AM 10/29/2003]
MikeC is offline   Reply With Quote
Old 10-30-2003, 08:24 PM   #15
Z-man
CF Senior Member
Z-man's Avatar
The answer to this question must also specify the tire/road contact patch specifics. 150hp would break the tires loose in the '60s with skinny, bias ply tires and high air pressure, yet a top fuel dragster won't break the tires loose with 3,000hp during a good run...
Z-man is offline   Reply With Quote
Old 10-30-2003, 10:10 PM   #16
Chuck Harmon
CF Senior Member
Default Re: How much power is needed to cut tires loose at 50+Mph? (Z-man)
Z-man,
Your point is well taken. A sticky tire will hold far more power than a standard one. The F1's on my Z are about as sticky a street tire as you will find. But tire width has little to do with the contact patch. The size of the contact patch is simply the weight of the car on any one tire divided by the tire pressure. The tire's width only defines the shape the contact patch will have: i.e. long and skinny vs. short and wide.
Chuck
[Modified by Chuck Harmon, 4:36 PM 10/31/2003]
Old 10-31-2003, 03:55 PM   #17
Z-man
CF Senior Member
Z-man's Avatar
Chuck -
Good points. It seems that the two important factors are car weight and coefficient of friction on the contact patch.
Maybe the original question could be answered exactly if it was phrased "How much power/torque is needed to cut the tires loose at 50mph with a 3200lb car and XXX brand tires?" Using a C/F of .84, I came up with 476.42 hp and 483.09 lbft tq. What did you guys get?? :jester
Also, I'm guessing the "stickier" the tire, the shorter the lifespan. I've heard some Porsches get only about 7,000 miles to a set. :eek:
Old 11-01-2003, 11:13 AM   #18
scorp508
CF Senior Member
scorp508's Avatar
All depends on how good/crappy your tires are in the first place.
I don't agree with that.
scorp508 is offline   Reply With Quote
Old 11-02-2003, 08:00 AM   #19
Rottenrob
CF Senior Member
Rottenrob's Avatar
One time I did roll into the throttle while doing about 60-65mph in 5th gear(1:1)on the freeway. If my memory serves me correctly, this was around 3000-3500rpm. The car lurched to the left and flat took off. I did not notice any tire spin though my passenger was terrified. ...
Steve
:lol: :lurk:
Rottenrob is offline   Reply With Quote
Old 11-03-2003, 02:15 AM   #20
Z-man
CF Senior Member
Z-man's Avatar
Default Re: How much power is needed to cut tires loose at 50+Mph? (scorp508)
Scorp - Haven't you noticed? The guy who gets even the smallest puff of smoke from his tires loses the race...!!!
[Modified by Z-man, 11:16 PM 11/2/2003]
Reload this Page How much power is needed to cut tires loose at 50+Mph?
Tags
50, corvette, mph, spinning, tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
flame orange jeaux C3 Tech/Performance 17 05-28-2011 12:55 PM
The C6 is one big piece of .... bcmarly C6 Corvette General Discussion 39 09-06-2004 01:37 PM
Launching a Z06 for drag racing oderja C5 Z06 Discussion 14 03-19-2003 11:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
