Gapless Rings and PCV system
1 Post
When running gapless rings, does the PCV system need modification? ...since there is less blowby. 1985 L98 - TIA
[Modified by GRX, 3:33 PM 8/1/2003]
Re: Gapless Rings and PCV system (GRX)
You need not worry that the oem PCV system will generate too much vacuum in the crankcase. Besides, how much vacuum is generated by the oem PCV system during WOT?
