AN fittings, how to measure?
Old 06-11-2003, 11:51 AM
scorp508
scorp508's Avatar
Default AN fittings, how to measure?
Can somebody tell me how to measure AN fitting sizes? I have a friend with an AN fitting at home, but he doesn't know what size it is. He needs an AN to 1/8" pipe adapter for his WWII jeep. So if I tell him to "grab a ruler and do this....." what would the "do this..." part be. :)
Old 06-11-2003, 12:21 PM
Lohkay
Lohkay's Avatar
Default Re: AN fittings, how to measure? (scorp508)
I'm interested in hearing about this but I would guess the AN sizes are in millimeters.
Old 06-11-2003, 03:33 PM
redvetracr
redvetracr's Avatar
scorp,
"16ths" so a -10 would be 10/16 or 5/8 and a -6 is 6/16 or 3/8 generally - numbers are even (4/6/8/10/12/16/20) BUT I have a -3 brakelines on my racer. Your best bet would be an Aeroquip catalog or a dealer because there is also the angle of the flare to think about. Perfomance AN fittings are 37degree who knows what they used in "the BIG one" WWll
...redvetracr
Old 06-11-2003, 03:39 PM
scorp508
scorp508's Avatar
Default Re: AN fittings, how to measure? (redvetracr)
Thanks, redvetracr. This might sound silly but where do you measure the 16ths from? Inner diameter of the line? Outer diameter?
Right now I am apt to tell him that he needs a -4 AN to 1/8 NPT from what you are telling me.
Old 06-11-2003, 08:11 PM
torquejunky
torquejunky's Avatar
Here's a link that should tell you everything you need to know.
http://www.amstreetrod.com/html/techhelp.htm#ansize
Old 06-13-2003, 06:25 AM
black bart
black bart's Avatar
Scorp another thing to be aware of is not all brands of hoses and fittings are interchangeable. I learned this the hard way for instance say you have a fitting by Russel and buy a hose from Earls you would think that if they were both the same size like say -4 they would fit but they don't. The id is the same but the od on the hose is different. Just though I would give you a heads up on that I bought some hose once that I couldn't use. :seeya
Old 06-13-2003, 08:22 AM
GregP
GregP's Avatar
Default Re: AN fittings, how to measure? (black bart)
Black Bart - That is true even within the same brand. Aeroquip in particular has several series of hose ends, each designed for a specific series of hose. They are not interchangable.
-Greg
Old 06-13-2003, 03:34 PM
redvetracr
redvetracr's Avatar
scorp,
One more piece of (probably useless) info, 37degree is also known as "JIC" ...redvetracr
Old 06-21-2003, 10:24 PM
Fast Glass
Fast Glass's Avatar
#4 - 9/16" wrench - 1/4" od tube
#6 - 11/16" wrench - 5/16" od tube
#8 - 15/16" wrench - 1/2" od tube
#10 - 1 1/16" wrench - 5/8" od tube
Don't kill me if the sizes are a little off. It's late, I have a few beers in me, and I'm working from memory. These are the most comon sizes I use at work on the airplanes. I also use these on my Vette. AN for aircraft does use a 37* flare. Trust me that an automotive 35* flare will seal just fine on aircraft fittings. I have them all over my Vette with no leaks.
Old 07-29-2013, 10:41 AM
moespeeds
moespeeds's Avatar
Would a 7/16" wrench be a -2 fitting?
Thx
Old 09-13-2017, 04:46 PM
Blacisi
Blacisi's Avatar
8 AN turned out to be 14/16. Which led me to this page which has really easy to use pictures.
http://www.russellperformance.com/misc/support/
caskiguy (09-26-2017)
To AN fittings, how to measure?
Quick Reply: AN fittings, how to measure?
