Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-25-2003, 04:25 AM   #1
reallycoolcorvette
CF Senior Member
Default what is the lowest compression a SBC can go with?
say a 350, 383 and a 406?
I am talking about how low of a compression ratio is available out there for these combos?
I ususally see 8.5:1 but if the answer is get larger CC heads for lower than I guess thats it.
reallycoolcorvette is offline   Reply With Quote
Old 04-25-2003, 03:30 PM   #2
Monty
CF Senior Member
Monty's Avatar
Default Re: what is the lowest compression a SBC can go with? (reallycoolcorvette)
Why do you wnat to lower the compression so much? Forced induction? Detonation resistance?
The lower the compression, the less efficient the engine. The same is tru for overly large combustion chambers. If you look at most modern engines and cylinder ehads, they trend is towards a small combustion chamber in an effort to improve combustion efficiency.
I would not go much lower than 8.5 or so, anything lower than 8.0 or so, and the engine gets really lazy and performance/efficiency really suffers.
Monty is offline   Reply With Quote
Old 04-26-2003, 04:07 AM   #3
reallycoolcorvette
CF Senior Member
Default Re: what is the lowest compression a SBC can go with? (Monty)
i definetly agree, just curious to thoughts on this matter.
Forced induction is the topic, for a full out race motor and 8.5:1 overall is the best way to go.
Old 04-26-2003, 10:03 PM   #4
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Let's see, now. A set of 6" rod deep dished blower pistons, swinging on a set of 5.565" 400 rods, 76cc chambered heads, and a thick head gasket, I bet we can get you down to 5.00:1- 6.00:1 pretty easily. I haven't done the math on this combo, but I'll bet we can get it even lower if necessary. Is the price of kerosene going up?
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 04-27-2003, 03:28 AM   #5
OatBoy
CF Senior Member
Default Re: what is the lowest compression a SBC can go with? (CFI-EFI)
that is a question i don't think i've ever heard before, even with a lot of forced induction 8.5 is really the lowest you would go, as stated above.
i want to know ....why?>>?
OatBoy is offline   Reply With Quote
Old 04-27-2003, 03:58 PM   #6
Vetterodder
CF Senior Member
Vetterodder's Avatar
Default Re: what is the lowest compression a SBC can go with? (OatBoy)
Going much lower than that will hurt torque when the engine doesn't have boost. Not so much of an issue for a dedicated race motor though as they only need to make power at high rpm where full boost is already there. On a street car though, where you normal use lower rpm more than high rpm, the engine could feel like a slug.
Vetterodder is offline   Reply With Quote
Old 04-28-2003, 04:10 AM   #7
reallycoolcorvette
CF Senior Member
Default Re: what is the lowest compression a SBC can go with? (Vetterodder)
kyah, i've been playing around with different cams and looking at their effects on cylinder pressure.
Final c/r will compliment the cam and vice versa.
Old 04-29-2003, 03:42 PM   #8
MikeC
CF Senior Member
MikeC's Avatar
My 350 had a CR at around 7.75:1..... ran really good.......14.6 sec in the 1/4 mile( not blistering but smog heads and a CR like that I figured it was pretty good.)
MikeC is offline   Reply With Quote
Old 04-29-2003, 09:18 PM   #9
reallycoolcorvette
CF Senior Member
Default Re: what is the lowest compression a SBC can go with? (MikeC)
7.75:1 compression?
that is pretty low for n.a.
Old 04-30-2003, 04:52 AM   #10
WashingtonRacer
CF Senior Member
Send a message via AIM to WashingtonRacer
Monty hit the nail on the head, I have been looking into this whole senario lately too, as I had to finally determine exactly what I wanted for a CR. I found it was not only the CR thats the issue, but the even greater issue is Quench height, which is just as important as compression ratio it's self. they both go hand in hand, and basically you will have to find a happy median between both to get the best setup.
WashingtonRacer is offline   Reply With Quote
Old 04-30-2003, 09:51 PM   #11
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Default Re: what is the lowest compression a SBC can go with? (WashingtonRacer)
Yes and no. Quench distance is MORE important than compression ratio. A shorter quench distance is likely to allow a greater compression ratio "work". Lowering the CR by increasing the QD, is more likely to cause problems (knock) than the origional (higher) CR. Little compromise is necessary if you plan ahead. Final tweaking, if necessary, can be accomplished by adjusting the combustion chamber size. This can be done by matching the chambers to the cylindar walls, unshrouding the valves, or just grinding back the plug side of the chambers. Piston dome/dish can also be massaged. Good luck, and...
RACE ON!!!
Reload this Page what is the lowest compression a SBC can go with?
Tags
compression, lowest, ratio, recommended, sbc, whats
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
supercharged 383 part 2 Mr Y Car Engine Mods 19 02-01-2002 12:39 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
