I am more than likely going to have my 383 removed this fall and it'll be replaced with a 420 cube short block. 4.155X3.875 are the dimensions. It'll retain my heads, cam and intake manifold.
I don't want to break the bank like I did with my 383..and was wondering since this,like my 383 doesn't rev past 5800-6000 if I could get away with a nodular crank..BUT use good pistons and rods. Compression will also stay at 11:1.
I won't be upping the HP numbers that much, but torque should have a significant increase which always makes for more fun and sotp feel.
maybe http://www.flatlanderacing.com has one. When I was searching for 3.875's I was able to find budget forgings made out of 5140 or something like that. I've also found some sub $500 4340 forgings.
JD, ck out the guys at Competition Products 800-233-0199, you should be able to get a Callies Dragon Slayer Forged crank for about $700.00 if that fits your budget. Good Luck
VETDRMS - I had one of those type cranks in a 393 ci. You really have to do the motor as a package. If you have a decked block that smaller amount of stroke is used to get the piston and gasket to get the correct quench.
IMO - The only way to build a motor is internally balanced and as long a rod as practicle.
gkull - I'm really not sure what your refering too regarding the package?...
I am building a 406 at the moment using an internally balanced crank with 6" H-Beams and SRP Flat Tops. The quench height will be .049" with my .010" deck height. Is that 3.875 crank from scat externally balanced?
It looks like the short block will be a bit above my limit. The 383 will come out of my car in the fall, and receive a full check over and what it needs it'll have done.
Don't know what your budget is. bill Mitchell offers 415/427 small block Chevy short blocks with forged crank, rods and pistons internal balance for $4600.00 plus shipping. Doug Herbert Speed at 800-444-7373 in a Motown block, a nice feature
VETDRMS - :nonod: SCAT makes a 9000 series 3.850" Crank,
I bought an externally ballanced 391 - 393 ci short rod motor. I think it had 5.65 rods TRW forged pistons. total junk!
What I was trying to say is; you have to get a stroke, rod, piston hieght to make your quench height correct with what ever your block is machined to.
I just went from a perfect setup with .038 head gaskets to a standard block blue printed. Then all the sudden my JE pistons with 6 inch rods were .020 down in the hole. so I had to buy .021 head gaskets to get me back to .041 quench
Ohio Crankshaft makes a 434 short block for $3495. unassembled or for $200 more they will assemble it.
It contains a Motown block, 4340 4" crank, JE pistons, internal balance, 6" rods, rings, bearings. They are new
to me so I don't know what there reputation is like.
Ohio Crankshaft: 1-800-333-7113 or visit their website @ OhioCrank.com
For you big block boys they also make a 555 to 588 ci. short block for $4100. assembled
Deen
