Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2003, 02:14 PM   #1
INMYBLOOD
CF Senior Member
INMYBLOOD's Avatar
Default Burnt vlave on Big Block ???
We are working on my brothers BB Chevelle it's a 72 402ss. We now believe the number 7 cylinder has a burnt valve. There is a flutter to the exhaust tone. There is no differance in how it runs at idle or reved with or with out this cylinder having the plug wire on. Tried different plug and wire no differance. This cylinders plug is fouled black also. The engine has always had a flutter to the exhaust tone. We have always thought it should run a little better. It will get a leak down test in the morning. I was just wondering if any of you have had this problem and if so how much different was the motor once fixed. I would really love to see this motor come alive for him. Thanks
INMYBLOOD is offline   Reply With Quote
Old 04-24-2003, 08:48 AM   #2
andy60
CF Senior Member
andy60's Avatar
Default Re: Burnt vlave on Big Block ??? (INMYBLOOD)
Gordon,
A simple compression test will let you know if you have a open or burnt valve problem.
If the compression test shows good then you may want to look at the cam (for a bad lobe) or valve train especially for a bent the push rod. Have you take the valve cover off? Can you get your hands on an old valve cover and cut the top off so you can run the motor and look at it?
But I am not telling you anything you do not know?
I know it is no fun running those problems down, good luck.
andy60 is offline   Reply With Quote
Reload this Page Burnt vlave on Big Block ???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
