Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2003, 06:59 PM   #1
piratemike
CF Senior Member
Default Another 400 Question.
Here is another 400 questio, this one concerning balancing. I already have a stock 400 crank that has been machined and is ready to use. I also have a set of 5.7" rods that I will be using. My machine shop recommended NOT going for the internal balancing and that I should use what I have and use a 400 flexplate and a 400 externally balanced harmonic dampner. Does this sound right to you? They said that typically, it takes a lot of added weight to ballance the 400 internally if you are using the stock crank(like I am).
Also, will using the 5.7" rods cause a balance problem when using the stock flexplate and dampner?
Any info or suggestions would be greatly appreciated.
Mike
piratemike is offline   Reply With Quote
Old 04-18-2003, 08:53 PM   #2
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Default Re: Another 400 Question. (piratemike)
I agree with your machine shop. Internal balancing a stock crank can get very expensive, for little or no benefit. In a super high output, all forged, engine, it is worthy of consideration. With a stck cast crank, in my opinion, it's a waste of money.
The 5.7" rods will pose no unusual problems. The engine will need to be balanced, of course, but the job will take the 5.7" rods in stride. Good luck, and...
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 04-18-2003, 11:51 PM   #3
sinistervette
CF Senior Member
sinistervette's Avatar
Default Re: Another 400 Question. (CFI-EFI)
:iagree: The rods will not have any ill effects on balance with your stock componants. :cheers:
sinistervette is offline   Reply With Quote
Reload this Page Another 400 Question.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Still Yet...Another Header Question Rich & Lisa_84 C4 Tech/Performance 19 01-01-2005 08:24 PM
Another AC question- why not on the solid lifter motors? Birdball C1 & C2 Corvettes 11 10-15-2003 10:21 AM
Another HP question sebrock C5 Tech 15 08-26-2003 09:57 AM
Another silly question. MagikDraggin C4 General Discussion 17 02-01-2003 08:47 AM
another 400 block question... Viking427 Engine Mods 10 12-18-2002 09:51 AM
Another Header Question fxrhm C5 Tech 18 03-10-2002 02:48 PM
ANOTHER HEADER QUESTION ????? vettecor C3 Tech/Performance 9 12-07-2001 04:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
