Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-15-2003, 01:26 AM   #1
GRX
CF Senior Member
GRX's Avatar
Default Missing oil passage plug
The machine shop forgot to install the oil passage plug that routes the oil to the oil filter. Now I need to do it and its something I've never tried...and I don't want to screw it up. Is there a "special" technique for pressing one of these in? I can't find any info on it. Any help appreciated.
[Modified by GRX, 9:27 PM 4/14/2003]
GRX is offline   Reply With Quote
Old 04-15-2003, 02:04 AM   #2
sinistervette
CF Senior Member
sinistervette's Avatar
Default Re: Missing oil passage plug (GRX)
You can tap it in using a pin that fits into the galley plug. I'm not sure the diameter of your plug, but I've used 1/4" and 3/8" drive extensions before. The female end of the extension fits nicely into the plug, then tap on the end of the extension to install plug. Use a screwdriver to feel how deep you need to go. Go just far enough to make sure you are past the lower cross galley( the one going to mains). You do not want to plug it off, but you also need to make sure you do not go too deep. :cheers:
sinistervette is offline   Reply With Quote
Old 04-15-2003, 02:06 AM   #3
bob
CF Senior Member
bob's Avatar
The plug drops in from the bottom and should fall about 1 inch down. Then with a 3/8 straight punch drive it down about another 3/8 inch. If you go too far you will restrict the oil to the engine.
bob
bob is offline   Reply With Quote
Reload this Page Missing oil passage plug
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Still missing at idle and low rpms Kdrhpe C4 Tech/Performance 9 08-21-2002 02:07 PM
Very Low Oil Pressure with Rebuilt Small Block/New Oil Pump. Suggestions? 70waiver C3 Tech/Performance 17 07-30-2002 10:02 AM
Nastiness found during head change! Smokehouse69 C3 Tech/Performance 18 01-01-2002 09:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
