Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-14-2003, 01:57 PM   #1
71roadster
CF Senior Member
71roadster's Avatar
Default how to determine push rod length
I know one way is to smear a little grease or something on the valve tip and the cycle the engine a couple times to determine where on the valve tip the rocker tip lies, but how do you keep the lifter from collapsing? My new heads are installed and I dont want to pull one off and have the expense and delay of installing 'checker springs' in place of a couple valve springs. There must be another way.
Anyone?
Chris
71roadster is offline   Reply With Quote
Old 04-14-2003, 06:06 PM   #2
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
Default Re: how to determine push rod length (71roadster)
put magic marker all over the valve stem tip and turn over the engine and the magic marker should be scrubbed off in the middle of the tip. use a solid lifter to do the checking. you can also get a moroso push rod checker at the speed shops and this little plastic item just slips over the stud and you follow the instructions on how to check the length
[Modified by clem zahrobsky, 5:06 PM 4/14/2003]
clem zahrobsky is offline   Reply With Quote
Old 04-17-2003, 02:22 AM   #3
gkull
CF Senior Member
gkull's Avatar
Chris we just did my buddies BBC Camero. We used the spark plug hole and air pressure with the spring removal tool. To pop the springs off. Then we removed the damper and inner spring to get the spring pressure way down for the checking and cam break in 25 minute period.
Refresh my memory on your setup. But the general rule is with stock valve lengths and standard base circle cams: under .520 lift with 1.5 or 1.6 rockers "Standard 7.800 push rods"
.520 - .590 standard length or .050 over with 1.5 rockers and .100 over with 1.6's
I have a bunch of lengths and I just installed one of each and rotated the motor. With sollids it's easier. Then just look at the side of the roller where it hits the valve stem tip. I could see that they were of center. I changed from a .930 small base circle to a 1.050. The difference should be a .120 from a previous setup. To me .100 is close enough. So that's what I bought.
The correct way is the tiney spring and the adjustable length checker. What if you had fairly heavy oil and you had the oil pump primer electric drill going. The lifters would be being filled some what?
gkull is offline   Reply With Quote
Old 04-17-2003, 05:12 PM   #4
71roadster
CF Senior Member
71roadster's Avatar
Default Re: how to determine push rod length (gkull)
Well after talking to my engine builder and getting a scowl for suggesting testing with a solid lifter, he showed me his trick. And its really simple. With almost any range of mild high performance cam there will only be about .125 - .150 inches of movement of the rocker tip across the valve tip. So that means with the lifter on the base circle with 1/4 turn of lash the rocker tip should sit about .075 on the high side (manifold side) of the center of the valve stem. So thats what I was shooting for and came up with stock + .050 length. Checked it by making my own checker pushrod out of one of the old stockers and had the builder measure. Gonna fire it up this saturday!!!
Thanks for your suggestions fellas.
Chris
Reload this Page how to determine push rod length
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
Home Port & Polish skydaman C4 Tech/Performance 19 06-25-2004 10:27 PM
Roller rockers on an L98 - stud length question The Dingo C4 Tech/Performance 20 03-17-2004 01:38 PM
Basic Z06 Questions from newbie MeefZ06 C5 Z06 Discussion 17 07-18-2003 08:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
