Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-14-2003, 01:41 AM   #1
johndezman
CF Senior Member
Default connecting rods for a 400 ci
i know the "factory" rods are short at 5.565" and 5.7 or 6" are preferred.
does someone make rods with the 400 rod journal and the longer length rod?
or do you have to get the rod journals on the crank turned down to the 350 size? won't this grind below any surface treatment on the rod journal? do you have to get the crank retreated?
johndezman is offline   Reply With Quote
Old 04-14-2003, 07:11 AM   #2
1979toy
CF Senior Member
1979toy's Avatar
Default Re: connecting rods for a 400 ci (johndezman)
The rod journals are the same size between a 350 and a 400.
The main bearings are not the same size.
1979toy is offline   Reply With Quote
Old 04-14-2003, 10:23 AM   #3
johndezman
CF Senior Member
good news! thanks for the info.
are the newer powdered metal or the old "pink strip" rods stronger?
is there a "stock chevy" 6" rod?
Old 04-14-2003, 03:59 PM   #4
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
you can buy 5.85 length also.
LD85 is offline   Reply With Quote
Old 04-14-2003, 04:17 PM   #5
johndezman
CF Senior Member
are those GM manufacture or aftermarket? are they PM or other construction?
Old 04-14-2003, 07:01 PM   #6
LD85
CF Senior Member
LD85's Avatar
http://www.flatlanderracing.com/crhbeamscat.html
I just did a quick search, I am sure there are others out there, but it makes your pistons cost a little more due to the 5.85 length.
Old 04-14-2003, 09:14 PM   #7
VETDRMS
CF Senior Member
VETDRMS's Avatar
Default Re: connecting rods for a 400 ci (ld85)
I have the SCAT 6.0" H-Beams in my 406.
I just did the mock assembly today to check for clearances, i'm using a standard base circle cam, and no problems! Everything fits great. I did have to notch the oil pan rails to clear the cap screws, but that's a simple
fix. Look for a website soon with lots of pictures> :cool: :cheers:
VETDRMS is offline   Reply With Quote
Old 04-14-2003, 09:34 PM   #8
1979toy
CF Senior Member
1979toy's Avatar
My 406 has 5.7" GM "pink" rods. They have to be ground at the inside bolt area for cam clearance. It is not easy to measure but you need a minimum of .030 clearance from what I've been told.
The 5.85 rod is an aftermarket rod only. GM did not ever make a rod in this length for the small block.
If you don't intend to rev this engine too high you could use the 5.65 inch rods and skip all the grinding or aftermarket rod business. You'd be surprised how many people are using the standard 400 rod for serious racing.
Old 04-18-2003, 03:03 AM   #9
The Dude
CF Senior Member
The Dude's Avatar
Eagle ESP 6" H-beams with ARP bolts over here...
The Dude is offline   Reply With Quote
Reload this Page connecting rods for a 400 ci
Tags
400, 585, rods
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
