Again, with appologies to SWDuke, whose dissertation I have no quarrel with, a little simple math bears out the cam card. For the sake of a "test" of the numbers, assume the cam is not asymetrical.
Quote:
Specs at .050” tappet lift:
Intake: Duration: 209*
Exhaust: Duration: 217*
Intake:
Opens at: -5.5 ATDC
Closes at: 34.5 ABDC
Exhaust:
Opens at: 46.5 BBDC
Closes at: -9.5 BTDC
Lobe sep angle: 114*
The intake duration is 209*. That would put the theoritical centerline with a symetrical lobe, 104.5*s past the opening point, or 110.0*s ATDC. (5.5 + 104.5 = 110.0)
The exhaust duration is 217*. This puts the centerline at 108.5*s past opening, or 62*s ABDC. (108.5 - 46.5 = 62.0)
Two points to remember, here. First: 62* ABDC is the same position as 118* BTDC. If you are at TDC, you go counterclockwise 118* to get to the exhaust centerline. Also from TDC you go 110*, clockwise to get to the intake centerline. 118* + 110* = 228* The second thing to remember is that because the cam travels at half crank speed the lobe centerline separation angles are measured in
CAM degrees. 228 / 2 = 114. SWCDuke's engineering and lab work, notwithstanding, it appears that the specs on your cam card "add up".
By the way, those specs should produce respectable sniffer numbers. Good luck, and...
RACE ON!!!
