Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-10-2003, 09:39 PM   #1
69 N.O.X. RATT
CF Senior Member
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Got the heads back, flow numbers post
I got the heads back today. I was hoping for a little more peak flow #s, but am more than impressed with the low and mid lift areas.
These are Edelbrock ovals tested at 28in
Intake: cfm
.200 / 148
.300 / 242
.400 / 282
.500 / 305
.600 / 313
.650 / 318
.700 / 322.5
Exhaust cfm
.200 / 130
.300 / 155
.400 / 179
.500 / 210
.600 / 220
.650 / 222
.700 / 227
Looking at the heads it is obvious there was a lot of work done to them. The chambers have been laid back a lot and looking down the ports on intake and exhaust sides shows almost no untouched area. The Victor jr. was also matched to the intakes. The work on the Victor jr. goes all the way up the the plenum area.
The heads were also flat milled .035 to raise the compression to almost 11 to 1. The chambers are 110 cc stock they are now 108.
The porter assured me the milling would not weaken the heads enough to worry about running NOS
Does anyone see any problems, i.e valve train geometry, etc.
Any thoughts are appreciated
69 N.O.X. RATT is online now   Reply With Quote
Old 04-11-2003, 01:08 AM   #2
korvetkeith
CF Senior Member
korvetkeith's Avatar
Send a message via AIM to korvetkeith
Default Re: Got the heads back, flow numbers post (69 N.O.X. RATT)
Yeehaw, looks like you might be makin 600+ on the motor.
korvetkeith is offline   Reply With Quote
Old 04-11-2003, 12:23 PM   #3
Glenn454
CF Senior Member
Glenn454's Avatar
Default Re: Got the heads back, flow numbers post (korvetkeith)
Great numbers John! Did you flow the heads before you had them ported?
You should make some serious power. :)
Glenn454 is offline   Reply With Quote
Old 04-14-2003, 08:00 PM   #4
427Hotrod
CF Senior Member
427Hotrod's Avatar
Great numbers. You can feed 600 HP with those with enough cam. Which you have!
Were the exhaust numbers done with a test pipe?
How long before it's running?
JIM
427Hotrod is offline   Reply With Quote
Old 04-15-2003, 12:27 AM   #5
69 N.O.X. RATT
CF Senior Member
Default Re: Got the heads back, flow numbers post (427Hotrod)
Glenn,
The heads were flowed before. I will post the numbers when I get the rest of the paperwork back.
Jim,
I should have asked but I do not know if they were done with a pipe or not. I should have it back together in 2-3 weeks.
When is yours going to be done.
[Modified by 69 N.O.X. RATT, 4:31 AM 4/15/2003]
Old 04-15-2003, 06:43 PM   #6
427Hotrod
CF Senior Member
427Hotrod's Avatar
I'm working on it, but work is been awful busy. Plus I got sidetracked a couple of days this last weekend because the Top Fuel guys were in town and I had to go out and get my annual "nitro fix"!!!
I got new TTII's installed with bigger tires, plumbed line lock last weekend, shortblock is all built. Cam sent out for a little "upgrade". Had a bad rocker, so Comp is rebuilding them under warranty. Had to return a bunch of fuel fittings. Summit decided somehow that along with all that Aeroquip braided line and A/N fittings, I must have wanted half of them to be push-lock type! Hopefully this weekend I'll install the Aeromotive fuel pump, regulator and tank sump possibly.
Still waiting on my heads, so I know what you've been through. Then I gotta port intake etc. Lots to do, but progress is being made.
I really wanted to make the Forum Cruise in...I dunno if I can pull it off. Time is getting tight. But spring is here and it sure hurts to have a convertible sitting in the garage!
Keep us up to date on yours. You're ahead of me!
JIM
Old 04-16-2003, 10:08 PM   #7
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
Good numbers Glenn and with the formula of CFM x .257 x 8 cylinders you get a rough idea of what the heads can support for horsepower.
But this doesn't take into account intake loss. An intake can easily take 20% off the numbers and if it reaches 25% they recommend a different intake.
norvalwilhelm is offline   Reply With Quote
Reload this Page Got the heads back, flow numbers post
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
After 11 brutal months the 383 (now 385) is now running luvmy92 C4 Tech/Performance 29 12-21-2004 04:09 PM
AFR New "LS" Cylinder heads..... Tony M C5 Tech 131 12-23-2003 02:02 PM
Heads are done, FLOW NUMBERS INSIDE! Nathan Plemons C4 Tech/Performance 24 08-26-2002 01:37 PM
Have $3000 to spend, need opinions -heads/cam OR headers and bolt-ons? 1quikC5 C5 Tech 20 08-08-2002 11:02 PM
1st Dyno #'s on my new A&A CNC Ported heads. Andy@AandACorvette C5 Tech 27 07-19-2002 12:21 PM
New Years Offer - Stage One CNC Ported Heads & Heads/Cam Mike@NorrisMotorsports C5 Tech 17 01-08-2002 02:20 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
