04-11-2003, 07:47 AM
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Re: Drag strip and a New Motor, Should I or shouldn't I...??? (HDIronman)
IMHO, For a STREET CAR, a min of 500 miles.
If it is all out Drag, let it rip now! A little oil use never hurt anything.
I have seen it done both ways, and watched some street cars suffer the oil use/wiped cam bearing blues if not broken in properly.
A key factor is knowing all the tolerances at build up too.............
If you have a main/rod brg problem, it will show up way sooner than 500 miles. bottom line, assesmbly tolerances are a big key to motor life.
Set them for the application and enjoy. My Long block has not been apart in my 68 Camaro since 1985....I built it, so I know every tolerance. It was broken in for ...500 miles, just like our 00' vette.
But at 501......:smash: :smash: :cheers:
