Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2003, 09:09 PM   #1
J Z06
CF Senior Member
J Z06's Avatar
Send a message via AIM to J Z06
Default [Soon, my LPE-383 is coming apart] Details inside
I've had an oil consumption issue(1000 to the quart) since day 1 of owning this engine. On my very first pass also, it has had a tendency to spit oil out of the dipstick tube under hard acceleration. The oil consumption is now down to about 750 miles. The engine has just over 40,000 miles and feels as strong as ever. Now, I am always prepared for the worst(I had to be with this car!!) and am ready to take some hints or pointers from some of you when this motor comes out and gets checked over. A VERY reputable local machine shop will be doing the work.
I would like to avoid the oil usage and especially remedy the dipstick tube ordeal. Again, it's done that since day 1. Did a ring not seat right or is one cracked? Also...it's been a little noisy on start ups(bottom end) but again, I'm ready for anything. I hear a quick knock and then it's fine.
fire away with any opinions, suggestions. I've never had a problem with consistent oil pressure as well so that's a major plus.
Thank you.
J Z06 is offline   Reply With Quote
Old 04-09-2003, 09:35 PM   #2
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
Default Re: [Soon, my LPE-383 is coming apart] Details inside (JD 90 383)
run a leakdown check before you do anything else so you know where you stand. are you sure you are not running too much oil in the pan. :chevy
clem zahrobsky is offline   Reply With Quote
Old 04-09-2003, 10:59 PM   #3
Monty
CF Senior Member
Monty's Avatar
Default Re: [Soon, my LPE-383 is coming apart] Details inside (clem zahrobsky)
I'd start with Clem's recommendations first. These days almost everyone, certainly LPE, uses moly rings on their performance buildups (unless they're forced induction with stainless/chrome rings) and they seat practically immediately.
Monty is offline   Reply With Quote
Old 04-09-2003, 11:07 PM   #4
J Z06
CF Senior Member
J Z06's Avatar
oh not to worry, i am fully prepared to do a leakdown. my luck it'll leak OK :lolg: if not, i am completely prepared for it to be removed.
thanks fellas, and i will keep you posted on it's progress.
i know this is the BRUTE POWER board...but i saw an l98 photo today of the engine painted the same color of the car. i DO like that look and might consider it.
:cheers:
[Modified by JD 90 383, 10:08 PM 4/9/2003]
Old 04-10-2003, 12:09 AM   #5
Monty
CF Senior Member
Monty's Avatar
Ohhhh, so it sounds like you're at least partially trying to justify something....what's next?
Old 04-10-2003, 12:17 AM   #6
J Z06
CF Senior Member
J Z06's Avatar
Monty, I kid you not and if He could type better than one word per hour ;)( :jester ) Frank would tell you. He had the EXACT motor I did before that beast of a 434 found it's way between the frame-rails in His camaro. It was a 383 done by Big John, d port vette heads, 219 cam etc. This was in late '91-'92. 440 hp n/a pump gas smog legal back then was tough to come by..so you see where I got the inspiration to do it. Frank beat the hell out of that thing for God knows how many miles...so I had to have one.
It has stayed in one piece even with repeated detonation and oil usage which shows LPE does build a strong engine. But at just over 40,K miles it shouldn't need a re-build, nor should I be spitting oil out the dipstick tube.
Thanks again for your feedback and for allowing me to rant a little.
Always somethin' ;)
[Modified by JD 90 383, 11:19 PM 4/9/2003]
Old 04-10-2003, 01:59 AM   #7
Goody
CF Senior Member
Goody's Avatar
Yeah, my vette uses about a half a quart every 1K miles too. But then, I just ticked over the 142K mile mark.....I want to do either a 383 or 396 N/A build in the next year or so. I have the top half so far.
I meant to state that I get a noisy start up every now and then too. I just attribute it to piston position at that particular time and whatnot. Never amounts to anything really.
[Modified by Goody, 12:01 AM 4/10/2003]
Goody is offline   Reply With Quote
Old 04-10-2003, 01:07 PM   #8
J Z06
CF Senior Member
J Z06's Avatar
Thank you for the feedback Goody.
I wouldn't care much IF the oil wasn't going at the rate it was, or if the dipstick didn't spit out. Those two concern me. And for the $ I spent for this engine, I really should NOT have to address these issues with the low mileage on it. BUT that's how it is.
Old 04-11-2003, 01:52 PM   #9
Vic'89
CF Senior Member
Vic'89's Avatar
Default Re: [Soon, my LPE-383 is coming apart] Details inside (Jay D 90 383)
Jay - Time for a 420 !
Vic
Vic'89 is online now   Reply With Quote
Old 04-11-2003, 06:19 PM   #10
J Z06
CF Senior Member
J Z06's Avatar
Vic
Vic
Don't think it hasn't crossed my mind :) (Cast crank 420 seeing they're like the 383's and don't spin past 6000 the spendy stuff isn't required.) :cheers:
Old 04-12-2003, 11:56 AM   #11
QuickVet
CF Senior Member
QuickVet's Avatar
What does the J.L. shop think. why didnt you take it to them a long time ago?
QuickVet is offline   Reply With Quote
Old 04-12-2003, 03:08 PM   #12
J Z06
CF Senior Member
J Z06's Avatar
Aaron
At the time, my car had a severe detonation problem that was being worked on by LPE. The oil thing was the last thing on my mind at the time. I also wanted to get the car back from them a.s.a.p.
Old 04-13-2003, 11:12 AM   #13
hookedup
CF Senior Member
hookedup's Avatar
JD,
Have you done the leakdown test yet? Results? Tonight I'll send you a couple of photos that will brighten up your day, what have I done to my car!
Hope you've found a simple fix, Dave :thumbs:
hookedup is offline   Reply With Quote
Old 04-13-2003, 02:12 PM   #14
J Z06
CF Senior Member
J Z06's Avatar
Dave
How are ya? How's the green machine? :) The leakdown test will be done tomorrow night. I'll keep you updated.
Which car are you working on? the '90 or the '92?
Take it easy....hope to see that monster at e town again soon.
Old 04-16-2003, 01:21 AM   #15
vettercr87
CF Member
Jay build a bigger motor if you take it out you know that you want too :D
vettercr87 is offline   Reply With Quote
Old 04-17-2003, 03:51 AM   #16
J Z06
CF Senior Member
J Z06's Avatar
There will be a slight delay on the results. It wasn't done yet. I will keep you posted on the outcome. :cheers:
Reload this Page [Soon, my LPE-383 is coming apart] Details inside
Tags
383, lpe
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
